Hi all,
I like to pressent the new EMS system KdFi.
It is a FULL management system.
I am working on an english translation on my website (http://www.bs-autotune.nl).
Anyway. It is based on an MS2 processor. It is a bare board with all components fitted. But excluding housing. It is SMD soldered so it is not a kit, it is ready to install in a box and wire it to the car. I have the manual here:
http://www.bs-autotune.nl/pics/KdFi/...320English.pdf
So: It is the MS2 processor. But the rest is enhanced. So it is not a copy, it is the better version. Insiders know MS has some issues. We have solved that on these versions. We have implemented the folowing features:
- full compatible to MSextra Software (Megasquirt®)
- MS2 onboard / Firmware MS2extra
- free Software / Open Source (MegaTune, MegaLogviewer, Tunerstudio)
- Fuel Table 16x16
- Ignition Table 12x12
- USB Conector (stable!)
- Dimensions only 100x120mm
- Widebandlambdacontroller JAW on Board (JAW Processor not included)
- header for JAW display
- Upgradeable up to 8 single coils (6 coildriverchanels are available but require patching and skills...)
- Knocksensor Input
- supports low impedance injectors
- supports 2 und 3 wire Fast Idle Valves
- user programable Relayoutput
- electronical boost control
- Tacho output
- permanent Barometric correction prepared
- Rev input via: VR-Sensor, Hallsensor or Coil at "Fuel only use"
- supports CAN Bus
The only thing you have to do is install it into the casing of your old engine management system, or like I have done: fit into a universal box. I can also do this for you like like on this pic with megasquirt compatible connector + Wideband connector.
It also fits into a motronic housing:
Here is a close-up of the connections of the board. The high-current grounds have seperate lugs to have a good connection.
Known tuningsoftware can be used. Here is a screenshot of the Tunerstudio software:
If you like it, feel free to start a group buy !
Selling price is 249 euro. But for international shippings out of europe I can take 19% tax of. Shipping will be around 30 euro worldwide. Shipping to european countries will be cheaper though. Starting at 10 euro.
If there are any questions, I'll be happy to answer them.
I hope to welcome you on my website. You can find some weird transformations over there !
