A lot of them tin sumps leak. I use VAG sealant at work and never had one leak! Part no: D 176 404 M2 (£19.74)
i have done a few of the tin sumps from retro ford and found the best way to get a leek free sump is to use the sealant supplied by dave at retro ford
is apply sealant to the block place the gasket on to the block sealant onto the gasket put the sump on nip up the sump only slightly (if you tighten up too much the gasket starts to slip out) then wipe round the gasket taking away all the excess sealant make sure there are no spaces gaps in the sealant then leave it overnight to set then tighten up and hopefully you should have a leek free sump
Not good mate
Can you use a later thick rubber type gasket from a CVH ???
i just ordered a new sump gasket from retro ford and there sealant 2i think they use a thick rubber gasket from a cvh anyway because they both look the same to me mate
thanks for the comments lads I will take the advise and use it.
engine back out tomorrow n gotta get new oil pressure switch too
if it aint broke, break it!
i have been doing some work on my escort for the first time in 3 or 4 months i picked up a atb lsd axle the other day.this way i can build the complete Axel off the car with complete disc conversion using sierra calipers and then swap the axles over later on.
i am going to need to weld some some brackets back onto the axel because they had been removed to be used in a national hot rod tigra.
but it all looks to be in good condition.
its already has front discs from a fiesta fitted but they dont have a mechanical hand brake mechanism fitted so these will be swapped
Atb lsd
The problem I have is the brackets that were supplied by dave sims designed to use the sierra caliper i have are drilled so the caliper can only be mounted dead above or below the hub.
Is there any reason why not to mount them like that?
The ones I have seen are mounted to the rear of the car as like on the fronts.
not only that but the caliper doesnt line up with the bracket anyway as there isnt enough room to get the caliper mounted to the bracket and get the disc flat against the hub. Ill post a pic so you see what I mean.
Fits inside wheel ok but is mounted dead centre at top or bottom.
Caliper problem doesnt fit
I adapted mine and welded them on mate I had to tho as I have a narrow axle and needed to clear the panhard rod bracket id move them where you want and weld them on
Got the engine back out yesterday. Hopefully fit a new gasket n sealant and bang it back in. Fingers crossed it dont leak.
Do It as Rcdunk says mate
Right then engine sealed and back in with gearbox n propshaft and no leaks!
Brakes n clutch left to do
brake lines are being rerouted up outside of inner wings to keep engine bay uncluttered plus easier to get to.
Engine bay almost finished
ive mounted my brake reservoirs but clearance under the dash is limited i really i need to fit a 90 elbow on the reservoir. or a banjo fitting but im having trouble trying to find them. anybody know where i can get the banjo fitting that screws into the plastic pot or as said 90 degree elbow.
hi mate
I had the same issue with mine regarding the clerance. you need a 7/16 elbow fitting I got mine from a hydraulic supplier. if I can find the.company I used ill drop you a pm
1974 MK1 Escort - Work in Progress
cheers matey
things are looking good i jacked the rear wheels up and ran through all the gears and seemed to work well.
cant wait for a test drive but need to sort the brakes first.
does any body know what thread connecters are used in a willwood hydro handbrake as there are two different size ports and i cant find connectors to fit?
Getting there now!
Not seen this one for a while good to see It taking shape great Job
Im waiting on cam pulley bolts for mine (st170 Install)
Thanks mate. Ive taken a 3/4 month break from the escort to restore an old motorbike.
The went touring spain on it for a couple of weeks.
Now its time to get the escort back on the road.
Good work buddy. Lots of changes since I last checked in!!
Yeah its almost mot able.
I keep finding more rust to cut out!
Just need to do the indicators, hazzards n reversing light then m.o.t. time.
Quick vid of brake test.
Mk1 escort zetec: http://youtu.be/CysnAOD8hUc
It moves and stops ....
well done mate
Good work mate, it looks like the finishing lines in sight.
thanks lads! its been a while but getting there now! but there are so many small things still to do though.
i aint giving up this time.
all moted now and oh my god its fun.
i took it out last night under the cover of night round a few roundabouts and industrial estates and went crazy.
donuts handbrake turns and line look burnouts oh yeah well worth the hard work!
i ragged the shit outta it for a long time and nothing broke!
i will try n get a few vids soon.
It doesnt look much different on the outside but goes a lot better.
Time to start to build a english axle lsd with discs on.
Seen this parked up today mate.... Good to see it back on the road :-)
Cheers dean. Saw the moggy outside your place the other day is it on the road now?
Im Still working on the axle as my son killed my diff doing burnouts.
Yeah mate the Moggy been on the road since March...
lol Fair play to the burnouts but not good killing the diff.... I have a lsd in the Moggy now, completely changes the car lol
Time to get it stripped down
Axle out time to build a better one
Gonna use mk2 escort single leaf springs n grind them down to 50mm on the ends.
2 inch lowering blocks n poly the lot.
The 1300 diff had taken a lot of abuse over the years so was due a change.
yeah cant get single leafs 50mm wide for some reason.
Mk2-3 Capri leafs fit, they're 50mm from memory. Had a pair on mine before I 5 linked it.
