What's the best kit available that is also best value for money available?
SUSPENSION ? ie shocks ?
My guess is brakes
Depends on the size of wheel and assuming you have the Capri uprights. If you can go to 15” then caprisport using the Mondeo calipers (gtr280) is a good buy. Need a bit if hub machining but that is not expensive. Gtr260 will fit under some 13” but uses the single pot xr4x4 calipers.
They do rear disc conversions using the xr4x4 calipers or I think the golf alloy calipers.
http://stores.ebay.co.uk/Caprisport-Direct
Sorry, yes Brake kit
