More parts no longer needed...
All these are heavy, so either collection from Bristol OR pls arrange your own courier. thanks
Complete set of 9” rear brakes. These are from a Capri with the backplates re-drilled to suit an Escort - £126
Complete set of 8” rear brakes, will need new seals - £58
Complete set of discs & M16 callipers off my Mk1 from last year – as you can see the discs are nearly new - £74
Pair of P16 callipers, will need rebuild - £48
Mk2 Escort hubs, as removed from car, complete with bearings, etc - £28
Mk1 strut mounts, shim washers, two-leg washers and spring caps - £12
