Does anyone have a crossflow rear drain dry sump pan they would swap for a full length channel one? Someone building a kit car maybe?
Hi MeXEco
I dont have a pan but i would be interested in buying your pan if you want to sell it as i think it would be suitable for my westfield
Ok mate i'll bear that in mind if i can find a suitable one for mine.
Think my ones steel so i could just make it a rear channel one with some plate welded in?
Go for it.
Cant see a problem with this-the scavenge pipe is towards the rear so if i cut just in front of this, remove the channel then plate over the hole.
Almost the same as Matt did with his notched sump.
Thanks Neil -any news on the crossflow manifolds yet?
As a matter of interest how much are you selling pans for ( if they are available to anyone) as i am considering coverting my westfield this winter? Also do you do the pump etc
Regards
Stu
We do all the Titan range of sumps 'n' pumps, e-mail me with what you need and we can sort something out neil@105speed.com
Cheers Neil
Cheers seen that one-going to have a go at modding mine.
