Results 1 to 3 of 3
Thread: XE + WCXM do you need to modify bulk head?
    May 2009
    Herts
    219
    Hi
    Can anyone confirm if it is possible to install an XE into a MK1 with a world cup crossmember without modifying the bulkhead?
    3,641
    Re: XE + WCXM do you need to modify bulk head?
    Yes, you can buy WCXM mounts, no need to modify the bulkhead provided you address the water jacket fitting on the rear of the head, either a short 90deg fotting if using a heater or blank it off if youre not using a heater.
    Dec 2013
    Beford
    233
    11
    I have a set of wccm xe mounts if you are interested
