Ford Crossflow alloy sump. Baffle is needed.
Just start working with the alloy sump i found from Ebay for Ford crossflow engine.
Sump is in very good condition exept original baffle is missed. Does anybody possible has original or similar baffle for sale?
I also need shorted oil pickup pipe.
Can anybody give me any tips how to build baffle for the sump?
What i need to know to secure correct lubrication thru engine?
Who is the manufacturer of this sump and what is the original purpose? Formula Ford perhaps?
Re: Ford Crossflow alloy sump. Baffle is needed.
formula fords were all dry sumped so it wont be for one of them. every x/f sump ive seen that loks like that is from a westfield or caterham
As you don't have a bowl on the sump maybe a lotus twin cam or pre crossflow type might work these are front bowl type pick ups. These are straight so could easily be shortened. they also have the strainer part on a spring so press down to the bottom of the sump. Maybe worth a look
