Results 1 to 8 of 8
Thread: Rust in fuel tank
    May 2009
    Herts
    219
    Rust in fuel tank
    Hi
    Does anyone have any experience in removing rust from inside a fuel tanks
    My MK1 Escort fuel tank has rust rattling around in side... Not sure how to proceed with sorting it... Is it DIY'able or are there company's out there that do this sort of thing?
    Bodger Duffer's Avatar
    Jan 2014
    West Sussex
    198
    Re: Rust in fuel tank
    Hi, you could try taking it to a powdercoaters and get them to acid dip it. Alot of wheel restorers acid dip the wheels to remove the paint/powder coating
    Trouble is you may find after this that you have holes where the rust used to be!
    Jun 2015
    Hampshire
    Look up Petrol Tank Sloshing (http://www.rust.co.uk/slosh-ethanol-...k-seal/p405062) they also have a cleaner to be used to remove rust before sealing the tank with the "slosh"
    9,204
    Rust in fuel tank
    Citric acid overnight will do it or if you don't have a few gallons then get some bilt hamber powder and mix it yourself. After u drain it keep the liquid to de rust other stuff. You will need to treat after cleaning as it will be fresh steel and rust quickly
    Frost do tank coatings.
    May 2009
    Herts
    219
    Thanks guys
    May 2004
    Norn Iron
    1,142
    A lot of radiator type repair shops can also tackle that sort of thing.
    And there are various treatments to offer a new surface inside the tank to protect it and seal it up again.
    9.85 @ 145mph 202mph standing mile
    https://www.youtube.com/watch?v=Ss_c7fML3rw
    May 2004
    Norn Iron
    1,142
    Apr 2012
    glasgow
    500
    17
    On my older bikes with metal tanks I use new small ball bearings to get the worst of the rust out then coat the inside of the tank with an expoxy coating although for some tanks it may be expensive
    It's this stuff here
    https://www.frost.co.uk/por15-car-bi...ir-sealer.html
    Keep her lit
