Escort MK2 Headlamps
Can anyone help me out with a bit on info ?
I have a set of reproduction headlamps (think most people now have them ?) and wonder if you can tell me what holds the headlamp beam unit to the surrounding adjustor ring
I can put some pic on if it help to explain my problem
Many thanks................
Re: Escort MK2 Headlamps
Not sure if yours will be the same, but I fitted a set of Ring lamps, I had to adjust the chrome rings that hold the lamp, so that they gripped the edge. Did this by putting the rings on a flat surface, and tapping the inner edge with a rubber hammer to reduce the gap between the ring and the holder. Does any of this mean anything to you
Merpo, I see what you're saying.........
It looks like my beam unit have three tabs that match three holes on the ring.
So my thinking is there's something missing to attach the two together, if you see what I mean
It sounds like you are missing the chrome ring which holds the head light in place.
Cheers,
Mick.
Fantastic............well not really !!!!!!!
So I am missing some bits.........the three tabs and associated screws.
Thank you very much for the pic.
Just need to explain to the shop that I didn't realise these bits were missing - bought them about 12 months ago
All sorted, so thanks again Gents...........
