mk2 escort N/S , passenger side inner wing
as title in need of a n/s inner wing small hole mine has rotted through where the battery tray sits.
Re: mk2 escort N/S , passenger side inner wing
Do you want just the inner wing, or the complete assembled inner wing as per AVO?
I can supply both (Magnum).
Regards
Tim
i only need to replace the bit where the battery tray is mounted because it's rusted through so i don't really want to buy a whole new inner wing if i can get away with it
I've had the same issue,
I've removed the battery tray and I just cut a piece of metal sheet, it depends of the hole, but seems a bit too much to replace all inner for that.
Then I replaced the battery tray, was too rusty also. I just kept the support of it.
The Following User Says Thank You to Mkdu For This Useful Post:
