Supercharged Crossflow
We have run the dyno our supercharged crossflow with very good results. However I now need to change the inlet manifolds for the Jeveys to a short one. Any one any experience with inlet track lengths on supercharged engines.
The engine specs:
Engine 1700cc Ford Crossflow – Originally Practical Performance Cars, Staff project
Lightened and balanced, Big valve head, Steel rods Forged piston’s 8:1 compression, HD push rods, Steel rocker post with roller rockers. Duplex timing chain, Fast road cam, Jenvy throttle bodies, Jenvy plenum, DTA ECU, Intercooler, Eaton E45 Supercharger with 10% reduction Pully, Simson Exhaust manifold 4-1 – Cam coated. Titan alloy dry sump, oil cooler and remote filter, -8 Aeroquip fittings and oil tank. Lightweight flywheel and clutch.
Feed back appreciated!
Re: Supercharged Crossflow
inlet track length will make no difference because you are not ram or pulse tuning
what power and torque did it make and any photos
The engine was originally a project with Practical Performance Cars magazine.
The engine was re-built by Cameron Gilmore run on Drumoak dyno. It made 160bhp an 140ft/lbs of torque. However we had huge heat issues from the exhaust manifolds proximity to the supercharger. Also a number of pressure leaks. We will run it on the rolling road and expect to find another 40bhp.
The exhaust has now been Cam Coated and we have a larger intercooler. It should be in the car over the next few week. Don't expect to run it until the new year.
Neil
