Results 1 to 16 of 16
Thread: cambering leaf springs the oposite way?
    Jun 2012
    ireland
    1,156
    Hi folks,
    odd question - i want to gain more rear ground clearance while keeping the softer leafs, 146 are way to stiff for the lanes - can i get my soft single leaf springs decambered the oposite way to raise the rear ride height?
    cheers!
    3,239
    Re: cambering leaf springs the oposite way?
    Initial thought is yeah why not although you are adding more 'camber' not de-cambering them. But one problem may be the rear spring hanger
    becoming more horizontal than vertical as designed due to eye - eye distance shortening due to greater curve. The more horizontal the hanger becomes
    the more ride ht. you lose. Probably be better to buy 118lb multi leaf springs at +1 or +2" ride height?
    Jun 2012
    ireland
    1,156
    can i buy them?! If so thats ideal! the only reason i was asking was becuase i didnt think there was such a thing!
    i know what you mean regarding the hanger, it might ruin the swing - or would it? if i could buy new soft springs with +1" height it would be perfect
    3,239
    Just had a look and they are tricky to find! Info from The Rally Prep. Manual - CD8 is 115lbs and apparently +1" - see attached
    Attached Files Attached Files
    Jun 2012
    ireland
    1,156
    yeah i have the book, i just assumed all the CD* springs were looong gone out of production stock? im surprised no-one is making them, why would burton any everyone else stock 146lb when they're useless on anything but a race car ? id say mine have sagged a fair bit too and i normally carry two spare wheels, a new-ish standard set would probably do me as good
    3,641
    What dampers are you using, i use 146's on the road with Bilsteins and find them soft
    Spanner Monkey Mkdu's Avatar
    Oct 2009
    417
    14
    same setup for me, 146lbs also with bilsteins, use in demo events, no issue, not too hard,
    but I've seen that bilsteins GP1 exists in different rate.
    Jun 2012
    ireland
    1,156
    bilsteins also, the old style upside down ones (piston attaches to the spring plate, damper body goes to the car)
    i've honestly never tried them, but ive heard and read alot of reports (on here) about them being way to hard for loose surfaces and they cause excessive oversteer, skipping across the surface of hard gravel or bumpy concrete etc.
    road car i'd be much more inclined to try, but i need good grip on gravel/grass etc which ive been told 146's dont give! ?
    3,641
    Ah ok, when you said lanes i thought you meant tarmac
    Both 116lb and 146lb genuine Ford GP1 springs would be ideal to use as neither are too stiff, however their supply will have long dried up.
    The problem now with all the after market springs that are available that no two suppliers are making the same poundage springs despite them saying that they are. How many of us have ever bothered to check.
    I bought a pair of Multi leaf 146lb ones from RACE. The springs have so much camber that the car is sitting like a Cart off one of the Western films.
    Bodger Duffer's Avatar
    Jan 2014
    West Sussex
    198
    27
    Didn't they back in the 70's produce longer rear spring shackles for exactly this reason? Seem to remember seeing them with different holes so the car could be raised to adjustable heights... But then you also saw people hanging red lights under the car to show off their shiny diff
    Quote Originally Posted by Duffer View Post
    That’s some memory I just about remember that along with extra wired in brake lights in the back window 😄
    Jun 2012
    ireland
    1,156
    hmmm seems there is no easy solution for this - which is extremely surprising. so what were saying is no one remakes anything under 146lb for escorts?
    Pit Crew Decade Plus User Blower's Avatar
    Mar 2004
    yorkshire
    Phone these guys up and see what they can offer , ive used them before for other stuff
    this is from another forum i use ....
    If you are looking to replace your MK1 or MK2 leaf springs look no further than Owens @ Rotherham. I have just had new 50mm multi-leafs made for my MK1 Mexico and they look great.
    I had them made from original drawings held at the company, with tapered and rounded off ends. They took two weeks approx' from order (although I was not in a rush), and I collected them last Thursday.
    Not fitted yet but will update with pictures next month. Price around £220.00 per pair depending on requirements, finish, auxileries etc.
    Further details:
    Owens,
    (Andrew Brightman)
    Aldwarke Road,
    Parkgate,
    Rotherham.
    S62 6BX
    Tel: 01709 710700
    Jun 2016
    Stoke on Trent
    74
    GARTRAC will decamber your old springs for you. I've got some 105lb single leafs and they quoted £115 to remove the old bushes, decamber and supply their Prop one's and deliver back.
    You'll have to delivery yours to them though.
    Jun 2016
    Stoke on Trent
    74
    GARTRAC will decamber your old springs for you. I've got some 105lb single leafs and they quoted £115 to remove the old bushes, decamber and supply their Poly bushes and deliver back.
