Results 1 to 7 of 7
Thread: Pinto coolant sensor in the coolant drain plug
    Jul 2014
    Aberdeenshire
    I'm looking for some info regarding putting a coolant sensor where the coolant drain plug goes on a pinto engine. I need one for the ecu and I don't fancy mucking around trying to fit it elsewhere.
    I've done a fair bit of googling regarding the subject but I just end up with conflicting information.
    I believe a sensor from a zetec will fit?? But there are a few different types of sensors fitted to a zetec and trying to buy one from a french motorfactors is impossible without knowing the exact year, model, part number and the middle name of the guy who fitted the wiper blades to the car at the factory when it was new.
    Does anyone know the part number of a sensor that will fit?? Or prehaps someone can confirm the thread of the drain plug...I think it's 3/8npt...but I have been known to be wrong on many occasions
    thanks,
    Kevin.
    Maybe the same sensor but have a look at cosworth temp sensor as well I think that is a 14mm thread
    3,239
    Re: Pinto coolant sensor in the coolant drain plug
    Personally I wouldn't recommend having a temp sensor in a 'relatively' cool part of the engine. I've got mine mounted in the stat housing so it gets the hottest water - used a common GM sensor for mine M12 thread.
    as above you need the sensor where the temperature is hot, either fit it in the inlet manifold water take off, or if your carefull you can drill and tap the head to take one along side the oe temp sensor, you have to be careful to both miss the manifold and head bolt hole.
    3,641
    Just fit a t piece where the current temp gauge sender is or in line in the top rad hose using a t piece, or thermostat housing which will be the same as fitting in to the top rad hose.
    2,659
    268
    I had an ally boss welded to my thermostat housing then drilled an tapped that for another temperature sender...
    Sep 2006
    chesterfield derbyshire
    2,162
    i run a pinto on efi with the sensor in the drain plug, you can get an alloy adaptor that screws straight in the block and then the sensor goes in that.
