Results 1 to 5 of 5
Thread: mk 1 escort inner sill picture request
    Mechanic bodger rogers's Avatar
    Oct 2008
    bristol
    865
    has anybody got a picture of how the rear inner sill end piece of metal inside the sill is shaped? as mine is totally rotted and gone, look!
    Click image for larger version Name:	ujggggggggggggg 009.jpg Views:	2 Size:	25.2 KB ID:	27660
    i need to fab a piece that joins to the outer sill but unsure how its shaped?
    if it aint broke, break it!
    Part of the furniture Decade Plus User Ratters's Avatar
    Mar 2004
    Bristol
    13,306
    77
    Re: mk 1 escort inner sill picture request
    i just replaced mine to suit tbh. not too bothered about it being 'perfect' or 'correct'
    phil [essyrwd] might be able to help you out though with a pic or two
    May 2007
    Up North
    1,774
    88
    Hello Mr rogersim going to see what pics i got.
    I have made a template of the rear infill panel that continues the inner sill .This welds onto the rear floor the bit that is under the rear seat .Ive made as near to the original as possible with the plug hole for the rubber bung because i like a challengeHope nobody tells me you can buy them .
    Link is for the pics of the plates i made with measurements on it you will need more if you want it spot on but it will give you an idea ,make one in cardboard then see it up with sill in place The plate has a lot of shapes to it to make it fit but you might be able to make a flat plate fit .If you need more pics i will take some when i get out in the garage .
    hope this helps
    http://www.turbosport.co.uk/showthread.php?t=133771
    Attached Thumbnails Attached Thumbnails IMG_3145.JPG‎
    IMG_3059.JPG‎
    IMG_3044.JPG‎
    b3.JPG‎
    b2.JPG‎
    IMG_3113.JPG‎
    Nov 2003
    Wirral UK
    7,322
    259
    A couple more for you
    There's lots more on my website at http://escort.accelerator.org
    Oct 2008
    bristol
    865
    thanks lads that what i wanted!
