bonnet cable pull
Can anyone tell me where the bonnet pull cable comes through the bulkhead, does it go into the front wheel arch?
Re: bonnet cable pull
anyone?? surely some one has bonnet pull on mk1 escort!!
Top bulkhead buy bonnet bracket and runs down side of wing rail lip
The Following User Says Thank You to AndyXlr8 For This Useful Post:
Comes up between the bonnet hinge and the wing. The cable runs down the top of the inner wing / drip rail, turns 90 degrees towards the front and then runs along the back of the slam panel.
The Following User Says Thank You to MegatronUK For This Useful Post:
ah that's brilliant thanks chaps!
Whilst on this subject, mine at early 69 1300 Super has the bonnet pull cable leaver bracket on the passenger's side under the bulkheads, is this normal for this year?
Or could it be where someone else in it's passed put it by mistake? If correct is it a case of getting a custom cable made up as all the ones I've seen for sale are for levers on drivers side.
my bonnet pull is on drivers side (rh) but there is no hole between bonnet hinge and wing rail and looks like its all original panel, gues ive got to get the hole saw out then!
