Results 1 to 15 of 15
Thread: Can i run a cvh turbo in rwd?
    Mar 2008
    perthshire
    Hi all can anyone tell me what box i would need to run a cvh in a rwd escort? if it can be done.
    I would want a turbo engine but would need to keep the size down so cant fit a 2 litre.
    Car is running capri crossmember so dont have a clue if it can be done and what engine mountings i would need.
    Dec 2006
    cambridgeshire
    361
    Re: Can i run a cvh turbo in rwd?
    didnt the sierra come with a cvh engine in rear drive format.
    Moderator+ Decade Plus User
    dangerousdave's Avatar
    Oct 2002
    London
    15,132
    65
    It has been done before, also im pretty sure the rwd cvh sierras are on a t9. There has been a few posts on here about rwd cvh turbos and the main problem that crops up is the turbo facing the wrong way. Do a search and you will find more info
    Mar 2008
    perthshire
    Thanks guys i will go have a look and see if i can find out more info.
    Spanner Monkey KENNETH's Avatar
    Feb 2007
    CORK, IRELAND
    230
    10
    yes it can be done, a fella up the road from me has a 100e with a rs turbo engine in it
    his name on the irishescortclub site is "pickupman"
    Spanner Monkey eliters's Avatar
    Jun 2003
    south coast
    278
    use a t2 frst turbo will face the right way then
    The great thing about this sig is by the time you've got this far its too late to stop!!!
    Sep 2006
    cambridge
    1,056
    Thumbs up Re: Can i run a cvh turbo in rwd?
    Yep ypo can run a cvh in a rwd t9 fits a treat to it just a bit of faffing about modding bits to fit as i know as i am half way through doing it
    Oct 2007
    middleton
    785
    There is two versions of the type 9,N1 and N3. N1 was fitted to 1.6-2.3 engines. The N3 was fitted to all XR4i's
    N1 gear ratios are 1st)3.65 2nd)1.97 3rd)1.37 4th)1.00 5th)0.82
    N3 gear ratios are 1st)3.36 2nd)1.81 3rd)1.26 4th)1.00 5th)0.83
    Some 2 litre pintos had the N3 version.
    I'm not too clued upon gear ratios,so I'm not too sure if the XR4i type 9 has advantages over the N1 type 9.
    Sep 2006
    cambridge
    1,056
    I think the 2 litre one is best why not check what ratios the std rst box had and work out gearing from that i know the v6 box has a longer input sharft so doesnt work but retro ford at corby does a spacer plate so it works hope this helps..
    Nov 2001
    in a cardboard box, westside.
    283
    yes you can RWD a cvh. dont bother with the sierra 1.8 cvh though as its renowned to be pap compared to the proper rs turbo cvh. a type 9 sierra 5 speed bolts straight onto a cvh and early zetec block with no mods needed. you will need to fit a spigot bearing to the crank. this is a standard pinto bearing. both cvh and early zetec are machined already to take this bearing so just needs pressing in. clutch- i found it more straight forward to have the flywheel redrilled to take a pinto clutch. less sodding around with mix and match parts. so with that done, you ready to go lmao! well not quite. forget the T2 as it runs out of puff at around 5000rpm although its fairly lag free but ultimatly id stick to a T3 and have a proper stainless manifold made to sit the turbo the correct way round. i made my own-
    the only other thing you going to need to make provisions for is the thermostat housing as its big and bulky and sits on the back of the cylinder head
    id recommend it though! its a great little engine (to me anyway lol)
    Sep 2006
    cambridge
    1,056
    Hi andy what starter did you use i have heard the dohc grananda auto one is the one to use? would you consider making another manifold??? Nice to see another rwd rst as everyone says it cant be done.Nice work...
    Nov 2001
    283
    i think your right about that starter. i seem to remember reading somwhere about that one was the one to use. however, i used a 1.8 sierra cvh one as i used the 1.8 zetec bottom end and flywheel. that starter will do both cvh and zetec-type 9 installations id have thought
    and sorry chap, but im not up for making another manifold as this took 3 days+ to mock up and make but there are specialists out there who can do much better than me anyway
    Jan 2013
    Bolton
    35
    10
    What engine n loom did u use I'm looking into this for my sapphire
    25,110
    the v6 box has the best ratios
    Racer Decade Plus User lincolndanny's Avatar
    Jan 2003
    Lincoln
    2,156
    Currently putting a 1.6 cvh Turbo in my mk1 escort. Efi block and 1.8 cvh sierra engine mounts with sump. Efi inlet and home made manidold are whats on my menu
    Real men do it Sideways
