On ebay at the moment (not mine):
http://www.ebay.co.uk/itm/172991294705
Very poor. It will suffer from freezing, fuel drops falling out of the air, fuel collecting at the bottom and if there are no "flaps" inside who can direct the fuel into the cylinders, number one will be running poor and nummer 4 very rich.
omg!
neither if drunk I'm able to make such ugly thing. Against any phisic law if intended for a carb
looks like you could play a tune on it.
would probably work better as an exhaust
I thought it was a Log type exhaust manifold at first glance until I noticed it said inlet. It looks like a 2.9 V6 XR Sierra throttle body might fit it.
It's DCOE flange. Don't even think about it, let along try it. it will run but terrible results at low RPM.
it would work nicely if you wanted to spy on 4 seperate people round a corner.
could it be intended for forced induction.?
Would make more sence.
i would imagine forced induction would make air/fuel distribution even worse!
No expert by any means but Cosworth Turbo inlet isnt much better is it?
