Results 1 to 36 of 36
Thread: Pinto on jenvey IDF throttle bodies
    Feb 2009
    in the shed
    132
    Evening.
    Was thinking the other night people seem to be able get very impressive gains using throttle bodies and mappable ecu on otherwise standard, zetec, duratec etc engines sometimes with upto 30bhp increases.
    Therefore could simar power gains be available on a fully standard 2.0 efi pinto except converted to use idf jenvey throttle bodies, down draught idf manifold with group one air box and mappable ecu.
    Any thoughts?
    25,110
    Re: Pinto on jenvey IDF throttle bodies
    gains on a standard pinto will be nothing like as impressive, probably only couple of bhp, what you have to bear in mind is the other engines you mention have heads which flow way way more air than a pinto, so the induction restricts power considerably, that is not the case with a pinto, if you port the head gains will be bigger, likewise if you add a cam (even a mild one)
    Feb 2009
    in the shed
    132
    Comments noted and appreciated
  5. #4
    Mar 2012
    2,118
    If you do want to go over to mapped ITB's, you better use DCOE style setup. The Ford Pinto IDF setup is not so super when you want real power.
  6. #5
    Feb 2009
    in the shed
    132
    Thanks for your reply Onyd
    I suggested the idf jenvey style throttle bodies because I've managed to obtain a group 1 airbox , which will give an engine bay look that was available from the factory/dealer for the mk2 rs. Also not really keen on the look of DCOE although I accept they could provide better performance.
    Graham
    Which stage of ported head would you recommended and would this include or need bigger valves?
  7. #6
    25,110
    something with some bigger inlet valves, it gets a good gain in flow
  8. The Following User Says Thank You to Graham For This Useful Post:
  9. #7
    Apr 2013
    S Wales
    230
    431
    Anyone seen or used the new Jenvey Heritage Throttle Bodies on a Pinto?
    They look nice, but not heard of any real world feedback on them yet.
  10. #8
    25,110
    its a throttle body its not going to work any better or worse than a normal throttle body, it just looks different
  11. #9
    Jul 2014
    Aberdeenshire
    I'll let you know how it works out once I finish mine I went IDF because my car is LHD and I wanted to keep the brake servo.
    Its not a standard spec pinto though. 2.1L, Stage 3 CTM head, Piper A8 cam ground to 120.5 degrees...to be honest I've got no idea what that means for the cam and the worrying part is that no one else seems to know what that means including Piper themselves but I was told that the cam should make decent torque. I went for 40mm Jenveys as they should flow better than 44mm IDF's.
    Still got to figure something out for the air filter. I wanted something that looked original but I think I'm going to end up with a couple of K&N's so I can fit some decent size trumpets.
    Kev.
    Click image for larger version Name:	Pinto.jpg Views:	396 Size:	102.2 KB ID:	82008
  12. #10
    Mar 2012
    2,118
    If this car is ment to be a fast-road, the A8 is way over the top. For the 120,5° LC, that's going to be tricky. If this is LC on the cam Lobes it can be OK. You will end round 112° LC at the valves. If this is grind 120,5 LC valves, it's probably on of the so many cam's grind wrong for me and now sold to you hahaha
    Please check, you should not end over 112° and only if this is a very fast engine. To be honest, I don't think this is the best cam for any IDF setup. This setup is far from as effective as for example DCOE style manifolds. And this cam need a real good head before it will start working. Same is true for the inlet manifold.
  13. #11
    Feb 2009
    in the shed
    132
    Interesting and useful picture Kev
    I managed to get a group one air filter from a German seller. They come up from time to time.
    I would appreciate if you could answer a few questions please.
    1. Which size idf style TB have you used.
    2. How are you connecting vacuum lines to the inlet manifold and brake servo.
    3. Did you source the TPS, fuel rail and throttle brackets from Jenvey.
    4. More pictures would also be welcome.
  14. #12
    Mar 2012
    2,118
    For the vacuum connection, I use both connections and fit one return valve in each line (strong vac. signal and no interpolation between cylinders). By occasion, next week I got a Capri is, fitted with this setup. I'll take a picture an post for you. It will be by the end of next week.
    I'm using K&N. If you ever got a spare Group one filter, please let me know, maybe I can have it reproduce if there is enough ask for. Can you send some pictures so I can have an idea how hard it will be to copy ? I never had one in my hands.
  15. #13
    Jul 2014
    Aberdeenshire
    Quote Originally Posted by rustyshell View Post
    They never seem to come up for me...Its one of my saved searches on ebay
    I'm using 40mm
    I'm doing the same as described above. The webcon IDF manifold has a take off on number 1 & 4. I'm going to use both.
    TPS - Jenvey
    Fuel Rail - Jenvey
    Throttle bracket - Webcon
    Throttle Cable - Ford
    Manifold - Webcon
    Unfortunately I'm not at home at the moment so only have this 1 other picture saved on my phone
    Click image for larger version Name:	pinto 2.jpg Views:	381 Size:	115.7 KB ID:	82016
    And for the injectors I've gone for the small weber type ones so the fuel rail will fit under the air filters.
    If you buy classic ford magazine... in one of last years issues they did a special on throttle bodies. March 2016 I think. It had an escort running IDF throttle bodies under a GP1 airbox. Looks like he used spacers on top of the throttle bodies. I can only assume it was because he used longer injectors and maybe also for the airbox to clear the rocker cover
  16. #14
    Mar 2012
    2,118
    Some IDF style ITB's use DCOE style air filter pattern. Maybe the spacer was an adaptor to make the GP1 filter fit without re-drilling?
  17. #15
    Mar 2012
    2,118
    Dear Kev Ush,
    Please send email direct to me regarding your question. For some reason there is and error with this mailbox and I can't send anything back.
    info@amtdyno.be
  18. #16
    Mar 2012
    2,118
    double post
  19. #17
    Jul 2014
    Aberdeenshire
    Dear Kev Ush,
    info@amtdyno.be
    Done!!
  20. #18
    Spanner Monkey Mkdu's Avatar
    Oct 2009
    417
    14
    Nice setup, but I don't know about the coilpack location.
    You're not far from crank sensor.
    I said that because I had an issue with a spark cable at around 30 cm from the crank cable sensor and it made some trouble at high rev.
    About double vacuum, interesting and it makes sense, thanks Dirk !
  21. #19
    Jul 2014
    Aberdeenshire
    Quote Originally Posted by Mkdu View Post
    I think the coil pack position should be ok. Ive see other people mount the coil pack on a cut down distributor. If I do run into any issues I'll just knock up a new bracket and mount it further away.
    For the brake vacuum I have been working on another solution if the vacuum from the 2 ports is not enough (although I think it will be enough)...
    Basically pretty much all modern cars run an electric vacuum pump to supply extra vacuum. Usually a Hella up28 pump. The up28 pump is used to provide extra vacuum for when a cars engine doesn't supply enough vacuum. You also get an UP30 and UP32 pump...these pumps can supply enough vacuum without assistance from the engine.
    Click image for larger version Name:	pump.jpg Views:	368 Size:	19.7 KB ID:	82017
    On the left is the standard coil. In the middle is an UP28 from a new shape corsa (although you can find them in most VW's and Jags etc) on the right is an UP32 from a Porsche. As you can see the UP28 is pretty much the same size as the standard coil. The corsa pump mount even lines up with the standard coil bracket so in my case I wouldn't have to drill any new holes to fit it.
    You do need to control the pump, it doesn't have to run all the time.
    For that I've found a vacuum ECU from a Jag x-type that will do the job. I think Mercedes also use the same ECU although I haven't seen a wiring diagram to back that up. the jag ECU just needs an ignition live, battery live, earth, signal from the brake switch and it has a feed to the pump. It has a vacuum sensor that is connected to the manifold via a 4mm pipe that senses when the vacuum drops below a certain level and kicks in the pump. I don't think I will need this at all but its there if I do and perhaps someone else can use this information if they are struggling for vacuum. Its all done with OEM parts so should be reliable.
    Click image for larger version Name:	ecu.jpg Views:	366 Size:	31.9 KB ID:	82018
    I haven't tested it yet but I will in the future when I have some spare time.
  22. The Following User Says Thank You to Kev Ush For This Useful Post:
  23. #20
    Nov 2008
    Bored
    1,380
  24. #21
    Jul 2014
    Aberdeenshire
    Yeah the last one on your list is probably the one I’ll go for. I don’t like foam filters. I wanted to go for a sealed air box and give it a cold air feed from the front but all the air boxes that are remotely affordable look like the inlet will interfere with my radiator and hoses.
  25. #22
    Feb 2009
    in the shed
    132
    Kev
    cheers for the pictures and answers.
    the article in classic ford march 2016 was the one that prompted me to go down the route with IDFs under a GP1 airbox.
    I agree the spacers look they are need to clear the rocker cover.
    keep looking for the air-box on eBay something will turn up or post an item in the wanted section, I managed to get my air-box for less than £240 it needs work but at that price couldn't say no.
  26. #23
    Feb 2009
    in the shed
    132
  27. #24
    Feb 2009
    in the shed
    132
    uploaded pics on pdf, cannot upload photos individually is there a file size limit?
  28. #25
    Feb 2009
    in the shed
    132
    Click image for larger version Name:	IMG_20180111_131105 c.jpg Views:	325 Size:	60.8 KB ID:	82041
  29. #26
    Feb 2009
    in the shed
    132
    Click image for larger version Name:	IMG_20180111_131105 c.jpg Views:	326 Size:	60.8 KB ID:	82042
  30. #27
    Feb 2009
    in the shed
    132
    Click image for larger version Name:	IMG_20180111_131000 a.jpg Views:	325 Size:	89.8 KB ID:	82043
  31. #28
    Feb 2009
    in the shed
    132
    Quote Originally Posted by Kev Ush View Post
    Attachment 82016
    pm sent
  32. #29
    Feb 2009
    in the shed
    132
    airbox trumpets and base plate now repaired
    Click image for larger version Name:	group 1 air box picture 3.JPG Views:	308 Size:	85.3 KB ID:	82184Click image for larger version Name:	group 1 air box picture 1.JPG Views:	309 Size:	116.4 KB ID:	82185Click image for larger version Name:	group 1 air box picture 2.JPG Views:	317 Size:	81.4 KB ID:	82186
  33. #30
    Feb 2009
    in the shed
    132
    Attachment 82184Attachment 82185Attachment 82186
  34. #31
    Jul 2014
    Aberdeenshire
    Nice work. Looks really good!!
    Kev.
  35. #32
    Jul 2014
    Aberdeenshire
    So just an update...
    My Capri was on the rollers today and made 131bhp at the wheels (159bhp flywheel) @ 7071rpm and 134lbft torque. I don’t know if the rollers read under or over but it drives spot on with plenty of power for the road which was all that mattered to me.
    Engine spec:
    2.1 on cast pistons
    CTM Performance Big valve head
    Piper (CTM performance) fast road cam
    Jenvey 40mm IDF throttle bodies
    Emerald ECU
    I’ll upload the print out when I get a chance.
    Cheers,
    Kev
  36. #33
    Mar 2012
    2,118
    28 Bhp "losses" sound like a lot to me but everything from 150 bhp and higher is a nice result for this setup. IDF style setup isn't the most performance way of inlet manifold. It start to struggle at approx 160 Bhp
  37. #34
    Jun 2019
    Newzealand
    33
    Hello im interested to know what cam you used. I have a similar setup making 128ftlb and 139hp at the wheels.
  38. #35
    Feb 2009
    in the shed
    132
    Evening can any post up some pictures of the throttle linkage for IDF jenvey throttle bodies please!!
  39. #36
    Mechanic snapper1's Avatar
    Oct 2010
    Chelmsford
    67
    668
    27
    It is important that the crank position sensor uses shielded 2 core cable with the shielding earthed at the ECU, in my case I use Megajolt for spark only and that is uses EDIS. The shielded cable is still important for fuel and spark ECU’s.
