Page 7 of 9 FirstFirst 1 2 3 4 5 6 7 8 9 LastLast
Results 241 to 280 of 339
Thread: Cortina MK3 2.8TT
  1. #241
    Dec 2008
    Finland
    35
    376
    Tom, this bmw gearbox has the spigot bearing inside the input shaft, that's why this tap is needed. Most of the gs6-53dz boxes are normal way around, but this box isn't. I think part of the 123d are like this. But all e60 models have normal input shaft what i have seen.
  2. #242
    Dec 2004
    Ireland
    1,781
    31
    Re: Cortina MK3 2.8TT
    Hi Sultzi,
    Thanks for that. I am thinking of doing something similar to adapt the end of the 2.9 crankshaft (Cosworth 24V) so that I can use a 2L type 9 gearbox with the shorter input shaft. I was a bit worried that if the adapter on the end of the crankshaft was not centred properly that it would run off a little and cause vibration or damage to the gearbox but I suppose that I can make the adapter fit into the location of the original spigot bearing.
    Great project that you are doing, I look forward to all your updates.
    Regards
    Tom
  3. #243
    May 2010
    london
    1,139
    Amazing build...love the work ...and waiting for the next update ...cool
    cheers mark
  4. #244
    Dec 2008
    Finland
    35
    376
    Tom, previosly I had that thing other way around with spigot bearing with cossy t5 box. It had too short input shaft just like t9. That worked nicely also.
    Thank you Mark, will be updating soon I think.
  5. #245
    Dec 2008
    Finland
    35
    376
    Update here, couple pics too.
    Propshaft back from welding/balancing
    Been wondering how to make wider rear arches. Decided to use front fenders arch at the rear. These have a bit more profile on them than original rear arches.
    Here one side all welded and grinded, it's pretty good
    Drivers side had been giving me headaches and now it's all welded up also but still not happy with it. Need to think what to do..
    Made bump stops, axle rests on them in the pics where wheels are on. There is still 18mm space to drop the car more with 2mm stainless shims. Will see what is the best height for the stops when i get the car moving.
    Power steering lines inside the car done and also under the car.
    Made new straps to hold the fuel tank in place. Original ones where broken of the tank.
    Couple AN10 fittings to radiator, one is from expansion tank and another one is the return from the turbos and heater core
    Paint on the pumps, so they don't look so dirty
    Also painted those valve covers, they came out pretty ok
    Trial pressurised the fuel rail again and now where no leaks
    So finally i could paint the intake manifold lower part and mount it to the engine with valve covers
    Same paint on the upper radiator hose outlet
    And also for the alternator bracket and oil filter adapter/sandwhich plate.
  6. #246
    May 2004
    Norn Iron
    1,142
    What length/diameter is the propshaft ?
  7. #247
    Dec 2008
    Finland
    35
    376
    Not sure actually of the lenght at all. It has spline in the front for rear axle movement because bmw box has bolt on flange at the rear. But shaft diameter is 3".
  8. #248
    May 2004
    Norn Iron
    1,142
    Only asking in terms of critical speed of a shaft, as it does appear quite long, and the car should go fairly fast.
    When I had a 1 piece on my Granada at first, it was around 57" I think. With my rear diff/tyres, which isnt short I couldnt go over 120mph without huge vibrations as the shaft's critical speed was too low. That was with a fairly slow shaft speed of around 5-5500rpm, but still too high for the length of shaft I had.
    I ended up needing a 2 piece shaft
    Maybe it isnt as long as it looks ?
  9. #249
    Dec 2008
    Finland
    35
    376
    Yeah, it might look longer than it is. I can measure it tomorrow if i remember. Havent thought that thing at all. Which is better for higher speeds? Smaller?
  10. #250
    Dec 2008
    Finland
    35
    376
    Quote Originally Posted by Sultzi View Post
    Ok, I did go and measure it up, it's 58,75" in total length and tube itself is around 44,50" long. 6gear is 0.84, so my top speed with 7000redline is 256km/h / 160mph.
  11. #251
    May 2004
    Norn Iron
    1,142
    shorter shaft, larger diameter will all allow a higher speed before it becomes a concern
    Likewise aluminium shafts, carbon will all have a higher critical speed for any given length/diameter
    7000rpm and 0.86 will result in a propshaft speed of 8140rpm.
    I'm not 100% sure if they take measurements of the steel tube, or UJ to UJ.
    For a 3" steel tube ( assuming wall thickness ) at 58.75" long...this calculator says http://www.wallaceracing.com/driveshaftspeed.htm
    you have around a 6300rpm critical speed. ie get close to that and there is a risk of the shaft destroying itself. Best analogy is trying to spin a flag pole...it's so long and flexible, resonances will start up which can be destructive. These resonances may not be visible in the propshaft, but I know from experience they can and will happen and the vibration they cause is nasty !
    MW has an easier chart, and it says it is centre to centre of the UJ's
    http://www.markwilliams.com/driveshafttech.aspx
  12. #252
    Dec 2008
    Finland
    35
    376
    Yeah, haven't really much ever thinked this, but make's sense. Somewhere they speak from center to center and somewhere just the tube lenght. Don't know does this type of shaft design which I have give any expection with the critical speed or is it just the full lenght what dictates the critical speed. If I remember right, I have .110" wall tubing, which little bit increases critical speed but also gives more weight which again lowers the critical speed?
  13. #253
    May 2004
    Norn Iron
    1,142
    centre to centre to me sounds like distance between supports...ie the UJ's
    By all means try and and see how it goes. But if you do experience a bad vibration...dont waste your time having the prop re-balanced or a new prop made the same again. That will not resolve the problem.
    I learnt all of this at my own expense several years ago. I ended up having a custom 2 piece made which so far has been well tested to over 10,000rpm shaft speed
    So you have 2 short shafts hence critical speed for each is much much higher than any single long shaft. Downside is it is more expensive, heavier and potentially weaker.
    My only other option would have been a carbon shaft, and whilst some may think they're great, I still wouldnt trust one to be strong enough
  14. #254
    Dec 2008
    Finland
    35
    376
    Shaft is from center to center around 55,5" (spline aprox the lenght what it's when installed to the car). This gives around 7000rpm speed for the shaft..
  15. #255
    Dec 2008
    Finland
    35
    376
    Been working with the car, still wan't this to be driven before winter and snow
    Modifying centre console to take exhaust back pressure gauges and water pump controller mountings
    All old paint needed to be sanded off before new paint.
    Fixed cracked heater box and mounted heater core and fuel pressure regulator to it. Need to change that gauge to sensor still.
    Modified gearbox fork pivot point with m10 bolt through the housing and then shortened to right lenght.
    Fork is in this position when it sits on the pressure plate
    And slave cylinder has this amount of travel with this setup, should be fine.
    Sanded and primed engine bay
    Painted, this car color seems to be very hard to get right so decided that the whole car needs overspray with this same color I now had in the engine bay. It's not much different, but too noticeable.
    Finally decided to buy bigger compressor to drive all the air tools. This has 200l tank and 920l/min of free displacement. So this is roughly ~700l/min displacement when working against pressure
    Sandblasted couple parts and then painted with hammerite
    Finally also painted top part of the inlet manifold and throttle body elbow
    Made line for the slave cylinder ready on the floor
    Then flywheel and clutch on the engine and then goes the gearbox too
    Little help with my friend shoehorn I was able to fit the whole packet in one peace to the car
    Propshaft and gearstick also mounted now, gears feel nice firm and short, very nice stick.
  16. #256
    May 2007
    Vic, Australia
    662
    133
    This just continues to impress... Cant wait to see what you are finally able to get out of it all...
    Shaun
  17. #257
    Dec 2008
    Finland
    35
    376
    Quote Originally Posted by escortinadriver View Post
    So am I Let's hope nothing inside the engine thought
    Been working with the car in the evenings because car is at my work (to access crane etc)
    Mounted brake and clutch master cylinders and made line to the clutch. It seems to work very nice, not too stiff at the pedal like the previous design was with same pressure plate and much more travel too.
    Mounted oil cooler and lines
    Fitted manifolds and turbos. Made oil lines complete and filled the engine with oil. Oil pressure came up nice with drill in seconds, so everything is ok.
    Brake lines made, a bit of a hassle back there..
  18. #258
    Dec 2008
    Finland
    35
    376
    Update again..
    Exhaust is now fully done! It's made from food grade 63,5x1,5mm stainless steel pipe and elbows. Whole system is tig welded with argon also inside the pipes to give most smoothest welds.
    Downpipes needed reducers, so we made them. Avaible reducers are so short that these give more efficient flow as being longer.
    Downpipes welded all way to x-pipe
    And pictures of the final product, happy with it. Took over 20hours by me and a friend to do and 210bars of argon. Rear mufflers will be painted black too..
    Also made wiring for injectors and couple sensors so I could mount fuel rail and top half of the inlet manifold.
  19. #259
    May 2004
    Norn Iron
    1,142
    Great work !
  20. #260
    Dec 2004
    Ireland
    1,781
    31
    Great work on the exhaust system. I am interested in the x pipe on a v6 engine. Do you think it will give more power or sound better. I was going to fit one to my v6 cosworth engine in my Capri.
  21. #261
    Dec 2008
    Finland
    35
    376
    Previosly I had separate pipes and didn't like it so much, friend of mine had x-pipe in his ls twin turbo and it did sound nice. So i'm just testing if this way it gives more smoother and meaner sound. Really don't give any advance to power in turbo cars, just the sound. But if you have n/a 24v it should be noticeable
  22. The Following User Says Thank You to Sultzi For This Useful Post:
  23. #262
    May 2004
    Norn Iron
    1,142
    generally either X or balance pipe will make it sound smoother. But then the turbos will also help do that too.
  24. The Following User Says Thank You to stevieturbo For This Useful Post:
  25. #263
    Dec 2004
    Ireland
    1,781
    31
    I am looking for an improvement in the sound. I was thinking for a H-pipe or x-pipe setup. I have searched but I cannot find any video of a V6 capri running x or H pipes. Looking forward to seeing and hearing this car working.
  26. #264
    Dec 2008
    Finland
    35
    376
    Been long week behind! After work I have been working with this every day to around 10-11pm. A lot of stuff that isn't visible been done..
    Engine bay almost done, downpipes are now wrapped with DEI Titanium heat wrap (bay is now pretty much done after this pic)
    Trunk ready with new electrics
    Small hole in radiator, friend of mine luckily did get this fixed for me..
    There was couple issues, but they are now sorted and the car runs finally! Exhaust sounds great (phone camera sucks, doesn't sound as good as it is). Next I need to take valve covers off and install inner valve springs to the valves.
    https://www.youtube.com/watch?v=aBIcPy8ts2w
  27. #265
    Pit Crew Decade Plus User raymondmarble's Avatar
    Sep 2005
    Dundee
    1,029
    116
    Amazing work, looking great! Can't wait to see it driving in its new spec
    Please 'Like' us on FB!
    https://www.facebook.com/pages/Jana-Kitchen-UK/393933930736835?ref=hl
  28. #266
    Jun 2006
    Durham, UK
    1,494
    Stunning work, absolutely stunning!
    If that motor goes as well as it looks, it should be a real treat
  29. #267
    Dec 2008
    Finland
    35
    376
    Thanks again
    Been working with the body lately, with help of a professional painter thank god..
    After pics I have sanded rest of the body prior to paint and also doors etc, also from underneath..
    Fuel pump broke, waiting for second hand to get the car on the dyno before snow.
  30. #268
    Dec 2008
    Finland
    35
    376
    Got the fuel pump and car is working again. Changed oil and filter for coming dyno tuning..
    Center console got new paint after modifications (water pump controller and ebp gauges)
    All sanded and ready for paint
    Two coats of color done
    And finally some clear to finish it off.. Also did assemble interior to the car..
    One important things to finish exterior are those wing emblems..
    Interior..
  31. #269
    Dec 2008
    Finland
    35
    376
    Hi guys!
    Car have been dynotuned now for off boost areas without boost pipes. It made 174hp at the crank and over 220nm. Small tuning where also made with spring pressure (0,6bar) all the way to 4000rpm where it started to push little bit coolant out from the expansion tank, so we stopped the tuning at that time. I decided to take the heads of to see what is the problem and see how the o-rings crushed to the head gasket. Biggest problem was that I didn't retorque head studs after few heat cycles, all where loose, turned maybe 10 to 20 degrees with same torque setting without opening nuts.
    Engine is now assembled back with new head gaskets and mopar head glue to help with the seal. I have now also retorqued the studs after heat cycle, all of them turned pretty much more. Need to check them maybe again after few heat cycles. Those o-rings make it hard to get right torque instantly. Next week back to the dyno to see the results
    Oh, also ordered new turbos because these what I have now are leaking oil through the seals.. But will go to make baseline tuning and we'll see what the changes are with the new turbo's They are garrett gt2860rs (discopotato) with ar .86 turbine housings.
    Car washed and idling again..
    https://www.youtube.com/watch?v=kX7vOOlqkpE
  32. #270
    Sep 2005
    Dundee
    1,029
    116
    What can you say? Just fantastic!
  33. #271
    thats probably a result of running it without any boost hoses attached, not only will the turbo overspeed but the lack of intake pressure wont help the seals keep teh oil where it should be
  34. #272
    fantastic work though the car looks great from all aspects, love the fact you kept the 1300cc badges
  35. #273
    Dec 2008
    Finland
    35
    376
    There where already some oil in the boost pipes before we started tuning, so seals where already broken. But good reason to upgrade little bit bigger turbo's now These are to small at the turbine side anyways..
    Thanks, maybe next summer I will get some miles on it
  36. #274
    May 2004
    Norn Iron
    1,142
    As there is no load against the turbos with no pipes attached, and equally very little airflow through the engine, they will not overspeed. A completely open pipe is not the same as say a small air leak.
    Some forms of racing actually use dump valve's to vent air whislt under full load to actually reduce impeller speed so they dont get into the surge, which can allow them to use much larger turbos without problems ( some drag racers mostly )
  37. #275
    Spanner Monkey Turbosport Subscriber Jimmythedimmy's Avatar
    Jun 2007
    Norfolk
    401
    seriously loving this car, congrats
  38. #276
    Dec 2008
    Finland
    35
    376
    Thank you
    So, today was dynoday and engine itself works beatifully, no problems with leaking head gaskets anymore. Just some mysterious rpm signal lost at 5600rpm. Will need to try with another sensor if it helps. Last time in the dyno it worked without any problems all the way to redline 7200rpm.
    But results measured to 5600rpm and from rear wheels are 338hp and 458nm at 0,8bar of boost. With 11% loss engine power would be around 375hp (we didn't measure losses in these runs because of that rpm signal loss problem..)
  39. #277
    Cortina MK3 2.8TT
    Excellent work this is a great thread well done
  40. #278
    Dec 2008
    Finland
    35
    376
    Thank you
    Problem solved with new Cherry made hall sensor.
    Car is now resting over winter, new turbos are arrived and also bmw propshaft too. Will update those in the spring first thing before driving more.
    Small soundcheck before putting to rest. Launch at 5000rpm and normal limiter at 7200rpm. Sounds pretty nice I think :P
    https://www.youtube.com/watch?v=JikTc38-04Y
  41. #279
    Dec 2008
    Finland
    35
    376
    Hi. Update on this, i have now changed new turbos and have made 2-piece propshaft. Its now at the balancing Shop.
    Did try at the same time when i made the propshaft what would the car sound with only open downpipes -> https://www.youtube.com/watch?v=ndZL4v5Va0M
    Made me think again To add some cutouts to the exhaust
  42. #280
    May 2007
    Vic, Australia
    662
    133
    Sounds good.
    Did you end up with larger turbos then?
    Shaun
