Page 8 of 9 FirstFirst 1 2 3 4 5 6 7 8 9 LastLast
Results 281 to 320 of 339
Thread: Cortina MK3 2.8TT
  1. #281
    Dec 2008
    Finland
    35
    376
    Re: Cortina MK3 2.8TT
    Hi.
    Yes, little bit bigger but still at the gt28 range. Old ones where 2860r with 44.6mm inducer compressor and 55trim and new ones have 47.20mm inducer at the compressor and 62trim. Turbine side wheels are the same, old housing was ar .64 and new ones are ar .86 (these are gt2860rs "discopotato"). So old ones where rated max. at 310hp and the new ones to 360hp. I'm restricted to use these gt28 series turbo's because car is road legal with those
  2. #282
    Dec 2008
    Finland
    35
    376
    And how the car looks at the moment
  3. #283
    Quote Originally Posted by Sultzi View Post
    how does that work? is there some list as to what you can and cant use?
  4. #284
    Dec 2008
    Finland
    35
    376
    First time I did get this to the road I had those smaller turbo's and needed dyno graph for the cars power to be under the maximum allowed. If I change those turbos to totally different kind of model then I need to get another dyno graph with those, which I don't wan't to do, pretty tricky If you understand what I mean.. In the car papers there is told what changes I have made to the car, intercooler, turbos (there reads just "two garrett gt28 turbos fitted). So there is couple different models under gt28
    But really, I don't think I need more power that these can make. Will see soon what the car will give with 1bar to 1.3bars when I get it to the dyno again
  5. #285
    May 2004
    Norn Iron
    1,142
    There are GT28's around these days with pretty good numbers...and they'll always spool well. No real need to change from that frame.
  6. #286
    Dec 2008
    Finland
    35
    376
    That's true, need to remember that base engine isn't the best choice at all, so I think gt28 frame turbos are enough for it
    Hooked laptop to the ecu and drove with my friend so we could adjust all the cruising cells at the maps to leaner. They were pretty rich after dyno, different thing to drive to downhill, uphill or level road with same tps and rpm. So we made adjustments to map correction table to get those most used cruise cells leaner, so after this I made the closed loop control to work. Maybe I get little bit smaller mileage with the tank
    Also finally made ball valve bottom of the breather tank, so draining it is now much easier than earlier. I always needed to take the wheel and inner fender out to open plug at the bottom of the tank. Now i just open this little hatch to open the valve and breather drains through small hose which is routed down between the fender.
  7. #287
    Mar 2006
    denmark
    22
    Cool
  8. #288
    Dec 2008
    Finland
    35
    376
    Friend of mine did call at wednesday that they would need a car asap to a car show which was taken that weekend. So I decided to back him up and bring my car there, because the another car did cancel just before the show, so they where in bad spot..
    Here is the pic when we got the cars inside and placed where we wanted them to be
    Random pic from driving around last night..
  9. #289
    May 2007
    Vic, Australia
    662
    133
    Nice pics.
    Shaun
  10. #290
    Jun 2011
    ireland
    61
    390
    33
    Just being curious or nosey ,are you limited to the engine size or output you can have in that model cortina as was available for sale in Finland ? or can you play with the worded definition they have in their rule books ?
  11. #291
    Dec 2008
    Finland
    35
    376
    Hi guys! Been a while and couple things have happened.
    madflow: you are right, we have pretty strick rules about engines and power. We can have 25% bigger engine than the biggest avaible here and 20% more power than the most powerfull version. This has been 2.3l v6 so this gives maximum size for the engine 2842,5cc and power 129,6hp. Size and power don't need to be from the same engine, you can take the power reference from the most powerfull and size reference from the biggest one. In this case they just are the same.
    But this just changed a little bit to allow any model from other countries to be the "reference model" (it just needs to be made by ford factory) where we can add those 25% bigger and 20% more powerfull rules. So now I can use that australian market 4.1l i6 as a reference so I can get 5111,25cc engine with max power of 189,3hp.
    So i'm putting old good 302windsor based engine to this, this time high revving n/a with quaife 69g gearbox (already have this, been in my room couple years waiting).
    Couple things already purchased for the swap.
    Donor engine from some truck. This will we used for all the mockup and "MOT" here, after that I will change the block to dart shp which can take the abuse of high rpms..
    Some chinese made itb's, these are very good for the price (i think somewhere around 1100£ for the set). Just need some porting on the inlet manifold and small tweaks here and there and change those stupid blue fuel rails to something else. Next option from states would cost over 4000-4500£! Need to change those trumpets to shorter ones, don't fit under the hood.
    Block in mockup
    Did cut the original engine mounts away and welded the plates (whats left of them) to the axle.
    Then I bought some Peterson Fluid system parts. R4 wet sump oil pump and bracket to sbf
    Remote filter mount with 1,5" thread. Wix racing filter
    Ati damper and peterson fluids spline drive system for oilpump and alternator
    Bellhousing for the 69g and windsor
    Engine mounts (to the block)
    Camshaft sensor to delete that ugly distributor
    And RHS 205cc heads with 2.02" inlet and 1.6" exhaust valves and 58cc chambers. These are bare only, will be buying some good valves and will be making hand porting myself. But these are very good as cast also.
    RHS valve covers
    "Couple" mandrel bends for the headers. These are 304 stainless, with 48,8x1,5mm OD size.
    Couple more items are on the way, will update when they arrive
  12. #292
    wow, thats a big change
  13. #293
    May 2004
    Norn Iron
    1,142
    Indeed !!! Curious as to why ?
    So much work was put into the turbo setup ? As for the fuel rails, you could easily have the anodise taken off them and re-anodised black or some other more discrete colour
  14. #294
    Dec 2008
    Finland
    35
    376
    Reason is because it's now possible! Just love high rpm windsor and I now get to use that quaife 69g which have been sitting around in my room waiting its turn. Always wanted to build v8 and now it's possible with this car
    When I started this car the cologne was the biggest I could put, but now because the law changed I need to make best of it!
    New engine will be e85 too.
    I more likely will be doing new rails from scratch than trying to use those But the butterflys seems to be good quality, these are copy of the jenveys, so shorter trumpets should fit.
  15. #295
    Dec 2006
    Essex
    233
    14
    WOW
    What kind of weight penalty comes with the Dart block ?
    Could you get away with a stoker kit once your MOT is sorted ?
    Keep the pics coming !
  16. #296
    Dec 2008
    Finland
    35
    376
    Thanks!
    Current block is late 80's so its lightweight cast. Dart block is much heavier due siamese bores and extra thick decks etc..
    I weighted the front end of the car without engine and tranny, its now at 330kg.
    Cant stroke, oil pan clearance is big issue with this Sierra power steering to get the engine low as possible. Will need to use original 3" stroke, but this is good for intended high rpms
  17. #297
    Dec 2008
    Finland
    35
    376
    Did check, dart shp block is 72,5kg this lightweight original maybe 40-50kg? Easily lifted by hands.
  18. The Following User Says Thank You to Sultzi For This Useful Post:
  19. #298
    Jun 2011
    ireland
    61
    390
    33
    i was only going to suggest the 3.8 american v6 essex , but now a 302 can be allowed--thats good news---how do you convince them now that it only puts out 190 bhp
  20. #299
    Dec 2006
    Essex
    233
    14
    [QUOTE=Sultzi;3056919]Did check, dart shp block is 72,5kg this lightweight original maybe 40
    That is much heavier !
    I'm sticking a 5.0 in my Sierra and as you say it's fairly easy to lift the block yourself, but they are fragile
    What I really want is a new aluminium Dart block - but can't afford that !
  21. #300
    Dec 2008
    Finland
    35
    376
    Same here, aluminium is out of my budget. Would be good tought.
  22. #301
    Nov 2004
    Sweden
    1,167
    Nice build, the engine spec is somewhat close to what I have in my distant mind for the next Capri project. Will be interesting to see how you get on!
    Gustaf
  23. #302
    Dec 2008
    Finland
    35
    376
    Oil pan almost done, only needs couple an10 fittings for electric oil cooler pump.
    These are Finland made billet stainless steel merge collectors, 48,3mm in and 3" v-band out.
  24. #303
    Dec 2006
    Essex
    233
    14
    Very nice collectors
    Are you going external oil pump to give the cam gear an easier time ?
  25. #304
    Dec 2008
    Finland
    35
    376
    Thank you! They make anything you like, you can check their site http://elmerracing.com/. These are extremely well priced, not pricey at all for the quality.
    Thats one reason for external oil pump, high rpm's and clearance issues in this chassis are couple more.
  26. #305
    May 2006
    southend
    47
    575
    This car just gets better my favourite classic ford !
  27. #306
    Dec 2008
    Finland
    35
    376
    Thank you mate! Dont like to walk the same path as everybody else..
  28. #307
    Spanner Monkey the1theycallthe1's Avatar
    Jul 2007
    The Midlands
    36
    305
    What is the black long fitting on the side of the sump?
    Awesome car!
  29. #308
    Dec 2008
    Finland
    35
    376
    Coarse filter before oilpump. No screen in the pickup, this replaces it and is cleanable.
  30. #309
    Feb 2008
    London, England
    157
    great work
  31. #310
    Sep 2005
    Wiltshire
    701
    All i can say is Wow. This car has gone from being compleated to another paint job and more upgrades.
    I really need to finish mine.
    Really good work.
    Paul
  32. #311
    Dec 2008
    Finland
    35
    376
    Thanks!
    Small update, got myself a custom radiator core from ceecee.fi, this was reasonable priced also. Size is 450mm x 600mm x 88mm and top of the core is 18fpi and lower part 14fpi. This is because lower part of the core don't get any straight airflow and smaller density core passes air more easily than top of the core which has higher density core to get more heat out where is straight air flow.
    Got the trigger wheel from lasercut and machinist made it to fit for the ati damper and made it round from the outer edge too (always small deviation after lasercutting)
  33. #312
    Dec 2008
    Finland
    35
    376
    Hi, small update again..
    Trial fitted block and oil pan to the enginebay and noticed that I still need to get the engine down more. So modified rack mounting points to get it around 20mm lower.
    And this gives problems with bumpsteering, so this will be sorted with cromoly tie rods and bumbsteer kit. Then I thought why not make new lower and upper control arms too from cromoly and put some gaz gold (already ordered) coilovers to the front. And then this means i can cut those original bumbstops out of the way and make the front axle more "pretty" looking..
    LS coil brackets all assembled, just need to find place for them..
    Now with modified front axle the engine sits lower and I was able to fit that nice quaife 69g behind the engine. Just needed little cutting from the tunnel, nothing major (already made it bigger last time for the zf gs6-53dz box). Now I can make engine and tranny mounts and after that I will get to make those headers.
    Got from Jenvey their ETA2 DBW servo and made mounts to the intake. Works nicely already, just need to tweak the balande rods a little bit later on..
    Stay tuned guys..
  34. #313
    Dec 2008
    Finland
    35
    376
    Little progress has been made..
    Did receive the clutch finally from Demon Tweeks, they had serious problems to get this, took 4months. Oh and their customer service sucks! So the clutch is Quarter Masters twin disc 7.25" "rally" version with ford 1x23 spline. Should hold 600lb/ft of torque, which is plenty enough for naturally aspirated engine. This rally version has little thicker discs to take more heat.
    Got pistons from Ross Racing, these are with 4.030" bore and 1.085" of compression height, dome is 17,3cc which will give around 14.4:1 cr with those 58cc heads. Compression ratio will be little bit lower because I need to make room for the spark plug in the pistons dome.
    Engine mounts and gearbox mount done.
    Next up headers..
  35. #314
    Dec 2008
    Finland
    35
    376
    Collectors in place, next up is starting to make tubes between them
  36. #315
    Dec 2008
    Finland
    35
    376
    Once again, been a while from last update Small things have been done.
    Started to make transitions for the header flanges from square to round pipe. Firstly I bought small wise and welded plate with same opening that exhaust flanges have.
    The wise worked perfectly
    After all 8 where done friend of mine did some tig welding (all are stainless) and finally we sanded them flat and grinded inside of them to look nice.
    I have also been thinking about coilovers to the front to get easier adjustment of the ride height. So bought some piping and plate made of chromoly steel and started to fabricate some tubular control arms for the car to accomodate gaz gold coilovers. Here are the lower control arms been made
    Here are upper control arms done
    Lower and upper control arms welded ready for first mockup, lower arm still needs tension bar brackerts to be made and I probably need to make that tension bar from scratch also (original one doesn't fit anymore).
    All bolted up, also have chromoly tie rods with bumb steer correction
    All good so far, wheels seem to have enough space to turn. Shocks are too long, need to buy 1" shorter ones.
    Got flywheel made by friend of mine with my own dimensions to work with the engine and quaife gearbox. Weight around 4,8kg with starter ring.
    Also got some injectors, Siemens Deka 114961 668cc high impedance and e85 compatible
    http://www.siemensdeka.com/product/6...fi114961-60mm/
  37. #316
    Mechanic beeRS's Avatar
    Apr 2007
    Chelmsford
    773
    114
    Fantastic fabrication here. looking forward to seeing more.
  38. #317
    Dec 2006
    Essex
    233
    14
    Great update
    Are you going to run an internally balanced crank ?
  39. #318
    May 2004
    Norn Iron
    1,142
    A re-working of the arms to push the shock further outboard would allow a shock with more travel and if you wanted a more upright shock. The fabrication is excellent, but in some respects a little OTT, especially the bracing on the upper arm which is forcing the shock to move so far inboard.
    The arms I made for my much heavier Granada are far less substantial than yours appear and work perfectly fine. I used Protech 2.25"'s on mine and ran them inverted as it made fitment easier, and arguably also makes adjustment easier as the adjusters are now at the top
    I tried to keep the shock as vertical in operation as possible to give it the most range of travel. It still isnt perfect by any means though..but then it never will be lol
    I also retained the original type of bump stop. I really didnt fancy the entire loadings of a "bump" going through the shock or it's fixings, and with such a heavy car I knew this could happen fairly often in hard use, especially with less then ideal suspension travel.
  40. #319
    Dec 2008
    Finland
    35
    376
    Yeah, everybody has their own ways to do things, this is my way. This isn't a race car so weight ain't a problem, I rather make OTT suspension arms than find myself somewhere hugging a tree or something
    Bracing on the upper arm really don't affect the shock position that much, big clearance at the moment. And I like to use the original upper shock mount hole if possible. But oneway to overcome too long shock would be to make new top mount to the subframe, will see.
    Probably will cut some excess material of the upper arm (from the point where tubes are welded together) and weld some end plate to cover it, looks a bit stupid now.
    Quote Originally Posted by Mark V8 View Post
    Great update
    Yes, much better way for high rpm n/a (and for everything else too in my opinion).
  41. #320
    Dec 2006
    Essex
    233
    14
    Any updates on this?
    I was wondering what your thoughts are on the Chinese intake ?
