Results 1 to 6 of 6
Thread: Need help with brake master cylinder
    Tyre Kicker Marquito2004's Avatar
    Aug 2006
    Lisbon Portugal
    Hello guys.
    I need some help from the "pros". The thing is i got a 1971 1.3 escort GT rebuilt to original specs about 6 years ago. When i did the rebuild i had problems with the original Girling master cylinder, so i sent the master cylinder to a shed that does the master cylinder rebuild stuff . But guess what 6 years past ant the thing is acting up again, the pedal goes all the way down, and i bled it several times. So im tired of it, but i want to keep the original look. So seaching the ebay ive seen this rs 2000 brake master cylinder ( https://www.ebay.co.uk/itm/FORD-MK1-...53.m1438.l2649 ). So the big question is, if your familiar with the product, will this fit? I´ve questioned the seller several times but he doesnt answer my questions, so maybe you whould know...
    Thanks in advance
    Clint's Avatar
    Jul 2001
    925,924
    Re: Need help with brake master cylinder
    You should have a single outlet cylinder originally all single outlet ones should fit fine BUT I would seriously think about replacing with a split circuit system, you can still make it look like it was meant to be there but its much safer.
    Aug 2006
    Lisbon Portugal
    Thanks for the reply Clint. Mine has allready two outlets, and its a tandem system. My question was more about the diameter of the two outlets beeing the same. because some years ago i heard from some guy, that the rs2k Master had bigger diameter outlets. One thing that i can do if thats the case is, changing all the brake lines to that new diameter. Guess thats a risk i will have to take...
    Ty
    Clint's Avatar
    Jul 2001
    925,924
    Not sure of diameter but they may be imperial on the Mk1 and Metric on the Mk2, I actually dont know, maybe someone else has the answer ?
    4,888
    What that guy probably meant was that a RS2 master cylinder has a bigger internal bore diametre.
    Aug 2006
    Lisbon Portugal
    Maybe thats also diferent Miniliteman, but my doubt was the one that Clint is speaking of. But no problem mate, maybe someone here will know thanks
