Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 41 to 80 of 146
Thread: escort mk1 rebuild with st 170 engine
  1. #41
    World Champion Decade Plus User Pitstop's Avatar
    Apr 2003
    Essex
    66
    4,809
    Re: escort mk1 rebuild with st 170 engine
    Blimey - some work to be done there. Good luck and keep us all updated.
  2. #42
    Bodger rvf-boy's Avatar
    Dec 2006
    plymouth
    74
    day off was this friday so i made my bulk head bit of a job to bend it but hear it is
  3. #43
    9,204
    good effort
  4. #44
    Dec 2006
    plymouth
    74
    got most of my jobs done so i wipped off to the garage and cut that nasty bulk head
    right out after making some carefull plans of size and position of every thing
    then poped the new one in place this one is cut back a bit
    to give more room for the st water pipes
  5. #45
    Mechanic mk2 wizard's Avatar
    Apr 2006
    Liverpool
    974
    That is one well shaped bulk head well done
  6. #46
    Dec 2006
    plymouth
    74
    thanks mk2 wizard it did take a bit of working out, so after lunch i cut the tunnel back
    a bit as the type 9 box had no more than 5 - 10 mm in places
  7. #47
    Dec 2006
    plymouth
    74
    more pics
    got the tunnel tacked back in
    engine bay looking better now added strengthening gusset as well
  8. #48
    Dec 2007
    Dubai
    1,678
    29
    Well that is one way of sorting out the grot, well done
    www.gulfpetrolheads.com
  9. #49
    Dec 2008
    plymouth
    31
    looking good mate, metal at last!! ill pop down again soon..
  10. #50
    Aug 2004
    Redruth, United Kingdom
    322
    Nice on mate, you don't mess about do you!!! Keep it up mate, and keep the photos rolling. This is a proper resto, end of.
    Work Hard, Play Harder !!!!!!!
  11. #51
    Spanner Monkey nitronig's Avatar
    Nov 2007
    grimsby
    250
    that looks pretty good mate
  12. #52
    Dec 2006
    plymouth
    74
    thanks guys just wish i put her in the garage in stead of the mini pick up, as the
    mini is as good as the day i left it there 7 years ago and the escort only
    needed the under wing splash shelds welding
    (bulk head ends) back then
  13. #53
    Dec 2006
    plymouth
    74
    well got the wing off got a bit of work to do hear i think
  14. #54
    Dec 2006
    plymouth
    74
    a piller is gone so spent hours getting door off sill top gone too
    all went wrong today twins playing up welder not feeding wire
    smooth door pins were a pig even though i welded a nut on
    them last time so i could just use a chisel to get them out but
    that did not work so i drilled the door and used the sledge
    worked a treat but this door is scrap anyway
    then drilled off the spot welds on heater bubble
    so i could cut top bulk head out
    made new bulk head top and tacked it in need to order full sill
    a piller pan and top plate for this side so i can crack on later
    this week
    just cleaning and welding to the good steel will cut the rest
    as it's strong enough to take it then in with more fresh steel
  15. #55
    Dec 2007
    Dubai
    1,678
    29
    Mate, I think by the time you finish there will be little left of the original, you are definitely a braver man than I
  16. #56
    Dec 2006
    plymouth
    74
    i ve done all the floor pans about 7 years ago and both rear
    arches for the second time so the backs not that bad this time
    seen yours you done fare bit as well, its only rust just cut and
    weld will get there in the end.
  17. #57
    Mar 2006
    In the garage getting cold
    1,448
    31
    Good luck with all the repairs
  18. #58
    Dec 2007
    Dubai
    1,678
    29
    Quote Originally Posted by rvf-boy View Post
    Yep, it's amazing how your mindset changes when you start cutting big lumps out and welding new stuff in. The small stuff I used to get excited about before, pales into insignificance
  19. #59
    Dec 2006
    plymouth
    74
    done a few hours today got a new a piller to go on so i cut off
    the old one
    had to repair inner door piller as the lower front edge was rusted
    as well
    have ground the rust off and put rust killer on
    was taking ages to dry so made up windscreen corner panel
    needs bit more work will fit this later left it to dry now till the
    weekend
  20. #60
    May 2007
    Vic, Australia
    662
    133
    Is there any car left???
    I cant believe what you guys repair over there.
    Unfortunately it makes some of what we still scrap look mint..
    Crazy, good luck with it all.
    Shaun
  21. #61
    Pit Crew Decade Plus User GAZZAMK2's Avatar
    Mar 2006
    Exiled in Lancashire
    949
    SHEEEIIIIIITE thats rusty!!!
    Good work there mate, your way braver than me. Hope all goes to plan for you. Keep the updates coming...
  22. #62
    Dec 2006
    plymouth
    74
    quick update been busy with garden and stuff so got out there
    this morning to weld a piller back on
    cut bulk head end out so it was easyer to get clamps on a piller
    and half ready for end to go on
    got the bulk head end back on too need to get it off the ramp
    so it needs to be strong
    sprayed zinc on the welds
    put the door back on to make sure it still fits
  23. #63
    Jan 2006
    in the garage
    101
    well done an other one saved, some really good work there, in the process of the same thing inc the st 170 heres a wee link to mine , might give you some insperation
    http://www.scottisholdskoolescorts.c...hp?f=8&t=11897
  24. #64
    Dec 2006
    plymouth
    74
    thanks alan you done a fare bit on yours i see how you getting on
    with fitting the engine in, thanks mark
  25. #65
    Dec 2006
    plymouth
    74
    not got much done today been bashing this bit of steel for what seems like hours but it fits well now
    hammer and dolly takes ages but cheeper than expressed
    and tacked in after i placed old wing back
    still need to shape top yet
  26. #66
    Apr 2006
    Liverpool
    974
    Nice one some good fab work going on there
  27. #67
    Dec 2006
    plymouth
    74
    been bashing most of the day got fare bit done
    finished this bit off
    and popped a patch in hear too
    cut the repair panel off was well strong
    2 cutting disk later and a good grind back left the cup
    in place to line up new top plate
    cut this out and made new bit
    popped it in place with few tacks will try and finish off tomorrow
  28. #68
    Dec 2006
    plymouth
    74
    been away for weekend to wales an escort mk1 i seen in a field
    last time i was there 2 years ago is still there looks like its
    been ripped in half will try the get pic off my phone...
    done a bit more yesterday painted my new wcx member ready to fit
    finished this bit off starting to stiffen back up now
    cut out old nuts and welded in new tubes cleand out and found some strong steel
    will put the rust killer on this then zinc it
  29. #69
    Dec 2007
    callington,cornwall
    152
    looking good mate !! most wouldnt be brave enough to tackle that kind of rot
  30. #70
    Tyre Kicker john b's Avatar
    Apr 2009
    scotland
    33
    well mate i take my hat of to you you,ve taken on some task there keep up the good work
  31. #71
    Jun 2007
    DEVON
    183
    coming along great mate, will be cgood to see it flying around plymouth
    1984 Ford Capri Laser..at heart
    Rebuilt/Restored/Modified
    Ongoing Project...
  32. #72
    Spanner Monkey mk1van's Avatar
    Aug 2007
    Wicklow, Ireland
    280
    gotta say man thats some work your taking on...WOW...bloody love it.... keep the pics coming
  33. #73
    Dec 2006
    plymouth
    74
    small up date been busy with the twins and garden/house
    got a few hours in and wasted most of it trying
    to get welder to work againe so got the new one set up now
    rust killed in side and zinc painted first then put this plate on
    to give me some were to weld the uprights back to
    welded second guset in hope to get this side done soon
  34. #74
    Bodger razorass's Avatar
    Mar 2006
    Raisio, Finland
    87
    Thumbs up for the effort but seriously You must have some serious issues
    How on earth that thing is that rusty? I understood it was stored? Where? in a salt water pond? Even the allready done floorpans are rusty so either the paint was utter crap or the storage has been really, really damp.(and the paint was crap..)
    I would have had the shell dipped or atleast sand blasted to get the rot away and a good look what's left of the car.
    Rotten V8; Ford Granada mk1 V8 N/A 500hp
  35. #75
    Bodger CPB's Avatar
    Jun 2009
    Northants
    24
    we shall rename you Braveheart
    for maybe frankenstien
    is there any good metal to weld to ? good luck mate
    hats of to you..
  36. #76
    Dec 2006
    plymouth
    74
    yep it was well damp and the bib was leeking all the rain in and keeping
    the floorpans nice and wet and i did not notice cause it was at my
    dads for all those years, i did not want to sand blast to bear steel so it
    could rust all over by the time i finished it . like meny resto jobs, and
    have seen some of the stuff thats been blasted down here, you could
    surf on the ripples, would have loved to have dipped it but dont know
    anywere to get it done, will sand blast in side when i am ready to
    paint the floor it looks worse in the pics but it is 1.6mm steel the pans
    were made from so i think they will be ok still if not ill repair them again, my
    aim is to cut all the rust out not cover it up so it can come back and bite me again.
  37. #77
    Jan 2006
    in the garage
    101
    your doing a great job keep it up
  38. #78
    Dec 2006
    plymouth
    74
    got a few more hours done last week
    and this friday 1 or 2 more hours had to cut in some good
    steel to weld the up rights back too
    both back in just needs quick grind and get the zinc on
  39. #79
    Dec 2006
    plymouth
    74
    hi all been finding it hard to get time to work on the escort kids
    are not sleeping much in the daytime now so its going to be one
    step at a time hears the latest pics
    cut the bumper mount stiffner out and chassis lower edge off
    repaired the edge and welded nice thick stiffner back in not much more to do this side now
    for now anyway i give all the steel a good coat of zinc
  40. #80
    Dan's Avatar
    Aug 2006
    north london
    4,378
    115
    thats some resto very impressive work
    keep at it, going on your metalwork so far it should turn out a cracker
