Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 41 to 80 of 130
Thread: Ford Taunus TC2 - now Trackday car
  1. #41
    Spanner Monkey Arieke's Avatar
    Dec 2008
    Belgium, Zandhoven
    438
    I have a problem with the acceleration of my car.
    See the problem? I lose time when the bounce.
    Last year i had the old saggy springs of 30 years ald and it didnt do that, and it drove better. I have spaxs dampers, but had them last year to. I only changed the springs over the winter with new stiffer springs. So that would be the problem right?
  2. #42
    Dec 2008
    Finland
    2,106
    62
    Do you have LSD in the rear axle? Cant really make out the problem from the vid bit do you get too much wheel spin or only one wheel spinning?
  3. #43
    Dec 2008
    Belgium, Zandhoven
    438
    the diff is welded so, so the should spin the same. If you look good, when i start the tyres bounce (the white car.) You can see the trunk rattle.
  4. #44
    Dec 2004
    Ireland
    1,781
    31
    Cant really see properly but that looks like axle tramp on a leaf spring car where the axle winds up and then releases which causes the axle to jump The Tanus does not have leafs but is the axle located at the top to prevent it twisting.
  5. The Following User Says Thank You to Group4_Mark2 For This Useful Post:
  6. #45
    Dec 2008
    Belgium, Zandhoven
    438
    it doesnt have leaf springs, ill make a pic from the axle and springs later.
  7. #46
    Dec 2008
    Belgium, Zandhoven
    438
    Here are some pics of the rear axle.
    An other question, can anybody tell me what for a axle this is. Last time somebody that worked for years on ford said it was an atlas axle. I just cant believe him, i dont think that they ever put atlas axles in the Taunus. But from pictures i have seen that this looks like the baby atlas, And that they are not to bad. Anybody an idea?
  8. #47
    Nov 2003
    Wirral UK
    6,740
    257
    Koln axles were usually fitted to cortinas and taunuses I believe.
    Regarding your spring problem, if the rear springs are too hard you won't get weight transfer to the rear on acceleration and therefore you will have less grip. The axle bounce (tramp) is most likely due to the void bushes in the top locating arms allowing the axle to wind up, then rebound.
    http://escort.accelerator.org
  9. The Following User Says Thank You to exboyracer For This Useful Post:
  10. #48
    Dec 2008
    Belgium, Zandhoven
    438
    You mean the 2 above the diff or the 2 that hold it to the chassis? or both of them?
  11. #49
    Nov 2003
    Wirral UK
    6,740
    257
    Normally the 2 above the diff are the worst, but you should probably check / replace all of them if they are the original rubber items!
  12. #50
    Dec 2008
    Belgium, Zandhoven
    438
    Going to try this i'll post pics later on
  13. #51
    Dec 2008
    Belgium, Zandhoven
    438
    So from the advice I got from here, I stuck new poly bushes all around the rear axle. Was a fun job drilling the old rubber bushes.
    And also I installed a second panhard rod ( i think dont know the english name) So it should be stiffer in the back and looks at the moment now.
    Some pics
    So thats for now, Going on a little vacation and the the car in going to a rollingroad, for tuning, will show graph from tests.
  14. #52
    May 2006
    322
    11
    arieke, that looks like axle tramp is going on when you start.
    some tips when i was starting of that same line in the escort :p
    get the rear softer inbound, there is hardly any weight transfer to the back, the rear of the car doesnt drop down when you lift off. the rear seems too hard. look at the starts of the volvo's in rallycross, they almost hit the ground when starting of the line.
    try to fit anti tramp bars to prevent it happening : simple installation. there should be plenty of pics on the forum. Or install a 4 link system that you set up so the car drops when starting from the line.
    i had the bugger axle tramp when i still had leaves on the escort. when i installed a 4 link system with a Z-bar is was gone and dramatically improved the overall handling.
  15. #53
    25,110
    in the uk, cortinas had a variation on of the atlas axle, so they are atlas's but not quite the atlas we have in our capris
  16. #54
    25,110
    thats an anti roll bar.
    a panard rod connects one end of the axle, the the chassis on the opposite side of the car ro stop the axle moving sideways
  17. #55
    Spanner Monkey Dr Knockers's Avatar
    Dec 2008
    London
    331
    27
    u have a koln axle there, some cortinas here that had the atlas type axles, i believe they are mk3,4 and 5's 2l + and some towing packaged cars had them fitted, if u can find one u can fit capri slipper
    To tell a heavy atlas type look at the bolt pattern on the diff plate if its symmetrical its a atlas type
  18. #56
    Pit Crew Decade Plus User bortaf's Avatar
    May 2004
    london
    1,021
    15
    Yeh that's a Koln (or chocolate axle) IE get it warm and it melts
    TBH with all that rear anti roll bar stiffnes your turn in will be very direct and cause more overstear
    i use a hyundai rear ARB it's 20 mm and about as far as i like to go on the rear
    Ii don't like to fully polybush the rear end, for 1 it will start to crack the mounts at the chassis end and it limits the axle movement and makes for a very very hard and skippy ride especialy on bumpy corners, personly i'd be softenong the rear and using rubber bushes at the axle end of the arms, if you want better axle locatuion you need to go back to rubber and add a panhard rod (if you can find an 81 to 89 hyundai stellar they have a cortina rear end thats 5 linked with slightly alterd bushes and a way way better than the standard taunus set up
    Although that is all based on playing with them for road use, never really rallyed one seriousely
  19. #57
    25,110
    Quote Originally Posted by bortaf View Post
    im certainly no expert on cortina's but that all sounds like very good advise
  20. #58
    Dec 2008
    Belgium, Zandhoven
    438
    So we went to a rolling road.
    The previous driver said it had 171hp. So, ... This guy, he set everything up, did first run and said its overfueling. To large air of fuel tubes. The previous owner had 170 (these were drilled) in the carbs, but it was overfueling, So he got some other and put 145 in the carbs and the engine made 150hp at 6100 rpm and same torque, So second run he put 140 in and the we got this.
    For a standard rs2000 engine I must say it aint bad. they had new 150hp and 190nm torque I even got 10 more. The fast road cams will make a difference. But that will wait they will fit in the rs2300 engine.
    The previous owner should have had the same probs with the overfueling,right?? it cant be from, something I did. Because i didnt change anything. I dont even believe the engine had 171hp because overfueling you always see on a rollingroad.
    Would rather see those 170hp. But he said his rolling road is a bit off. So ...
    This is a link
    http://www.arieke.be/TS/mycompetition/taunus_2liter.bmp
  21. #59
    May 2004
    london
    1,021
    15
    I think pretty much all dynos differ from each other, they're only really usefull for comparisons if you use the same RR every time to keep track of the mods you fit IMHO.
    That's still a pretty good result though what sort of millage has the engine done ?
  22. #60
    Mechanic cuttsy224's Avatar
    Sheffield
    29
    539
    67
    nice to see someone doing something original for once!
    also, i think the matter is that the man told you the bhp at the fly wheel (so it seems powerfuller than it is at the wheels) the dynor might possibly have told you the bhp at the wheels
    hope this helps
  23. #61
    Dec 2008
    Belgium, Zandhoven
    438
    the engine had I Think 10 years ago a fresh build, new rings and bearings. So should be still oke. If i do a full season of Rallycross I maybe do 160km, The engine would have 1500 on it so. Still fresh i asume. Every year a oil change. and filters.
    Original? :-p Its a bit modified, But there aren't alot of go faster parts for these engines. expect cams.
  24. #62
    Dec 2008
    Belgium, Zandhoven
    438
    Last weekend 22 august on the race at last the diff broke. So i opened it up today and the satelits are broken, so the rest is intact. Pinion and crown wheel are oke. So Will be taking the old satelithousing out and fixing it and hopefully i can fix it before the event in holland starts. Will post pics of the diff.
    I had fully bushed the rear axle and yes my problem is solved, it pulls nicely off the start it was awsome, till it broke. had lots of fun with it on saterday
  25. #63
    25,110
    sounds like you fixed the first problem, now your probably gonna keep breaking diffs
  26. #64
    Dec 2008
    Belgium, Zandhoven
    438
    we are going to fully lock the diff. We going to fill the satelite housing with melted pistons. So it forms a solid block so, this should be stronger then just welding the teeth together.
    People say the this is a chocolat axle, but what actuallty breaks? Pinion? crownwheel, shafts? of the satelits?
    If i get the full locked diff back i will put a pic on. It will be cool.
  27. #65
    Dec 2008
    Belgium, Zandhoven
    438
    So I got my new diff back, it is I think stronger then before. We made 2 flat sides on the satelite wheels en made a metal piece and placed it in the satelite housing. And the rod that holded the knackerd satelite wheels in place, we used it again to hold the metal piece in place.
    Pics:
    I had a go with it, Its been tested and it didnt break yet, I dont assume it will break. If something now breaks, it will be the half shaft or the whole housing.
  28. #66
    Dec 2008
    Belgium, Zandhoven
    438
    So at last I found the cortina atlas axle. Went to Germany drove up 600 km. And wel worth it but now. I dont know what diff ratio to get.
    I would like to keep my MT75, because i modded whole the tunnel and driveline.
    My powerband is from 2500 rpm 175NM to 4600 rpm 200NM and At 6600 175NM So it aint high revver.
    13" MT75 + 4,63
    16, 9,6 6,2 4,63 3,5
    RPM 1 2 3 4 5
    1000 6 11 17 22 30
    1500 9 16 25 34 44
    2000 12 22 33 45 59
    2500 16 27 41 56 74
    3000 19 32 50 67 89
    3500 22 38 58 79 104
    4000 25 43 66 90 118
    4500 28 49 74 101 133
    5000 31 54 83 112 148
    5500 34 59 91 124 163
    6000 37 65 99 135 177
    6500 40 70 107 146 192
    7000 44 76 116 157 207
    MT75 + 5,14
    18,5 10,6 6,9 5,14 3,9
    RPM 1 2 3 4 5
    1000 6 10 15 20 27
    1500 8 15 22 30 40
    2000 11 19 30 40 53
    2500 14 24 37 51 67
    3000 17 29 45 61 80
    3500 20 34 52 71 93
    4000 22 39 60 81 107
    4500 25 44 67 91 120
    5000 28 49 74 101 133
    5500 31 54 82 111 147
    6000 34 58 89 121 160
    6500 36 63 97 132 173
    7000 39 68 104 142 186
    MT75 + 5,8
    20,9 12,0 7,8 5,8 4,4
    RPM 1 2 3 4 5
    1000 5 9 13 18 24
    1500 7 13 20 27 35
    2000 10 17 26 36 47
    2500 12 22 33 45 59
    3000 15 26 40 54 71
    3500 17 30 46 63 83
    4000 20 35 53 72 94
    4500 22 39 59 81 106
    5000 25 43 66 90 118
    5500 27 47 73 99 130
    6000 30 52 79 108 142
    6500 32 56 86 117 153
    7000 35 60 92 126 165
    I got some price from fostek 225£ for 4.63 300£ for 5.14 and 5.8 for 440£
    Somebody told me on this forum the best gear diff ratio is 11 for racing. So the 5.14 is the closed to 11. Any body have a bit advise? Yes The first Gear wont be any use only for in the carpark. So second Gear is the starting Gear.
    in 2011 mid season i will start building a 2300 RS engine, and cams. So power wise the car will have more Torque.
  29. #67
    Jul 2011
    Paris France
    15
    Any news?
    Don't Scrap it, Restore it !
  30. #68
    Spanner Monkey Luke's Avatar
    Sep 2006
    Perth Western Australia
    392
    Yeah whats been happening?
  31. #69
    Sep 2003
    Barbados
    1,284
    19
    Quote Originally Posted by Arieke View Post
    Re posted the pics
    Any info on the distributor setup?? it looks like a CVH one but don't the weights in dissy work the other direction??
    1973 mk1 escort
    1982 Toyota corolla ke70
    1988 mk4 escort
  32. #70
    Dec 2008
    Belgium, Zandhoven
    438
    Quote Originally Posted by Luke View Post
    Been long time, i recently build a 2300 bottemend. This or next week i hope to port the head a bit so it can flow some more air. Just waiting for the inlet manifold. (i'll post pics from block) the one i have is to restrictive.
    Quote Originally Posted by SidewaysMk1 View Post
    I think its a CVH one, but when i got a new cap and rotor they gave me parts from a rover :-s. so i' wouldnt know
    For the rs2300 I'm going to use a pinto distributor from my blown up pinto. I don't know about weights. i thinks it turns in the right direction. clockwise like the pinto ones.
  33. #71
    Dec 2008
    Belgium, Zandhoven
    438
    Plans for this winter are,
    Succesfully build a rs2300 and hope for 200+hp and +185 lb/ft of torque.
    A new exhaust is build build because i can't build exhaust. Will add pics when I get the car back.
    A brake upgrade and only in front. My disks have a verry nice blue color after the race. So going to fit 260mm vented disk and clamps from the scorpio with red dot pads. And a master cilinder from a 2.8 granny. I hope this works. (i still have the standard brakes on the car)
    An other things is installing servo. (steering) because turning the steering wheel is hard and trying to down shift doesnt work that good. (2:1 steering) And its killing my shoulder. I have a rack from a sierra dohc.
    And of course some bits and bobs.
  34. #72
    Jan 2011
    clacton essex
    1,731
    70
    how u guna make a pinto dizzy work on the 2.3, cant u use an esc1 pack that some people use 4 the zetec conversion, i have an esc 1 pack running the ignition on my rs2k with carb, its about 50 quid ish, but looking gd all the same
  35. #73
    Dec 2008
    Belgium, Zandhoven
    438
    info on r2300
    some pics.
    A scorpio 2300 block with sump from a 2.0 DOHC from a sierra because then i can remove the balencer shafts. less weight more revy
    Using a Rs2000 head with RS2BP300H RALLY cams, (these are the latest cams you can use before getting rid of the hydrailic tappets) and adjustable camshaft sprockets. and a moddified pinto dizzy from H&H.
    Took of 1.3mm from the pistons, because cr is to high if you use rs2000 head you get 11.8, what is nice you i had forged pistons and better con rods. But thats a bit to much for the standard pistons. the rs2000 had 10.3. I'm hoping for 10.6 - 10.7. But I don't know much cr they can take so trying to do a safe build.
    Thats all for now i think.
  36. #74
    Dec 2008
    Belgium, Zandhoven
    438
    going to make it the same way it works on my rs2000 engine. To be fair i wont know how to install it. And would believe a moddified dizzy by H&H would have a better advance curve. the pinto dizzy I got was build for a race engine. so i would asume its better then a sec1 pack. or am I wrong?
  37. #75
    Dec 2008
    Belgium, Zandhoven
    438
    pics of engine
    Click image for larger version Name:	rs2300_1.jpg Views:	244 Size:	58.2 KB ID:	49212Click image for larger version Name:	rs2300_2.jpg Views:	246 Size:	50.1 KB ID:	49213Click image for larger version Name:	rs2300_3.jpg Views:	247 Size:	69.3 KB ID:	49214
    for some reason, i couldn't upload the pictures.
  38. #76
    Sep 2003
    Barbados
    1,284
    19
    pinto dizzy Weights go the right direction for your setup. i Also use a cut down pinto dizzy on my DOHC 8V.
    Where did u Run the outlet for the expansion/filler tank on the BMW rad to?
    1973 mk1 escort
    1988 mk4 escort
  39. #77
    Dec 2008
    Belgium, Zandhoven
    438
    euhm, I don't have a bmw radiator anymore, for some reason unknown. (I had a T piece connected someplace.) I have now a 2.3 v6 cortina radiator and its still runs hot the dam engine.
  40. #78
    Dec 2008
    Belgium, Zandhoven
    438
    I Did some porting work on a test cilinderhead. Not sure of its any good but, first time.
    Before
    Click image for larger version Name:	Afb0323.jpg Views:	248 Size:	41.8 KB ID:	49451
    After
    Click image for larger version Name:	Afb0322.jpg Views:	247 Size:	42.7 KB ID:	49450
    It does look like an improvement.
    Don't know if this actually does something, This should be the top from the port. My dad said it wont make a difference so, I don't know. Advice welcome
    Before
    Click image for larger version Name:	Afb0325.jpg Views:	247 Size:	42.4 KB ID:	49452
    After
    Click image for larger version Name:	Afb0324.jpg Views:	246 Size:	34.0 KB ID:	49453
  41. #79
    Dec 2004
    Ireland
    1,781
    31
    looks much better to me. definitely help with some power
  42. The Following User Says Thank You to Group4_Mark2 For This Useful Post:
  43. #80
    Dec 2008
    Belgium, Zandhoven
    438
    I have calculated the cr from the engine and it will be 10.7. Standard the 2300 has 10.0 cr and the rs2000 has 10.3. So i hope 10.7 won't be to high. Would give a little more hp anyway. :-)
    I just hope the rings can stand it and the piston doesn't melt. Pinto's standard pistion can withstand 10.5 al day long so. Hopefully these a little bit more :-s
