ECU and Kill switch
Hi All
just on with my mk2 wiring and is it ok for the ECU to run thru the kill switch ?
So every time the kill switch is off the ECU loses all power ? The car will still use the standard ignition switch as well .
cheers paul
Re: ECU and Kill switch
its not a problem and for competition they have to be wired that way.
Cheers for that Graham
