Page 1 of 2 1 2 LastLast
Results 1 to 40 of 50
Thread: Ignition Timing for Modified Engines
    Dave's Avatar
    Oct 2003
    Cheshire
    19,588
    141
    This is a copy and paste from Dave Andrews old homepage. The homepage isn't there any more after AOL closed Hometown. I am putting it here as I often refer to it, lots of good information. Hopefully Mr Andrews won't object, if he does I will remove it.
    An often neglected but important area when tuning an engine is the ignition system. No I don't mean harder plugs, competition coils, lumenition etc., that only affect the efficiency of the spark, but the actual ignition advance supplied by the distributor. Tuned and modified engines have different advance characteristics and requirements from a normal engine. Adapting the advance curve to meet these requirements using the standard mechanical distributor is not that difficult a task once it is understood. This area is often considered to be a black art, but it is actually quite straightforward.
    Correctly setting the advance curve for a modified engine can make a considerable difference to the tractability of the engine as well as ensuring that the engine is giving of its best power wise.
    Modifying the advance in the way described can only be done on an engine that uses mechanical advance. Some engines use mapped ignition which is electronically controlled, Ford ESC, EECIV, Bosch K,L Jetronic, Motronic are examples. These are not suitable for modification. A quick and easy check to see if your distributor has an advance mechanism is to remove the distributor cap, grasp the rotor arm firmly and try to turn it in a clockwise direction. If it allows 10 or so degrees of movement and then springs back, then it contains a centrifugal advance mechanism and is suitable for modification, if it is rock solid, don't mess with it, its mapped.
    Why an engine needs more advance as its speed increases
    When the compressed mixture inside a cylinder is ignited it takes time for the flame front to reach the piston and for the expanding gases to start pushing it down. The time that this takes changes according to a number of variables such as mixture strength, how well the cylinder has filled (dependent on volumetric efficiency and throttle opening), compression ratio and combustion chamber shape. Given the same circumstances of mixture strength, cylinder filling and CR, the time taken for the mixture to fully ignite and burn is the same regardless of engine speed. At increasingly higher RPM however, the time available for this burn to take place is correspondingly less, so it follows that you have to start burning the mixture earlier in order for it to push on the piston at the right time. This is the basis for increasing ignition advance.
    Too much of this and the burning mixture hits the piston as it rises (pinking or pinging), too little and the flame front reaches the piston far too late and does not do a good job of pushing the piston down and the engine behaves like a herd of turtles. One of the reasons a diesel engine does not perform at higher RPM is that it has compression only ignition, so there is no way to increase the effective ignition advance.
    How this is achieved
    The distributor as fitted to conventional ignition systems does not just distribute the spark amongst the cylinders and switch the coil; it also contains a centrifugal mechanism that advances the ignition timing automatically as engine RPM rises. Normally there are a pair of weights within the distributor which under the affects of centrifugal force tend to be thrown outwards, this tendency is greater as RPM increases. The weights are shackled by two small springs that restrain them progressively. As the weights move outwards they exert a turning force on the top of the distributor shaft relative to the driven part of the shaft, this moves in the same direction as the distributors rotation thereby causing the points/electronic trigger to actuate earlier and advancing the ignition timing. As engine speed increases the weights overcome more of the spring's tension and advance the timing still more. There is normally a stop of some kind that limits the amount of advance that the distributor can supply. This centrifugal mechanism is usually hidden away underneath the baseplate of the distributor.
    Vacuum Advance
    Under conditions of light or closed throttle, the volumetric efficiency of an engine is quite poor, and cylinder filling is affected to the extent that the effective compression ratio is much lower than the static or calculated compression ratio. In these circumstances the mixture will burn much more slowly than with a fully filled cylinder and the flame front will reach the piston quite late. This can dramatically cut the overall efficiency of the engine and its economy. Under these conditions the engine will tolerate and indeed benefit from advancing the timing by up to 15 degrees over its normal setting.
    The device that usually performs this trick is called the vacuum advance device. The way this works is to exploit the partial vacuum that is present in the inlet manifold when the throttle is closed or partly closed. A tube is connected from the manifold to a sealed diaphragm in the distributor, which in turn is connected to the distributors base plate. The suction deflects the diaphragm which turns the base plate against the direction of rotation of the distributor thereby advancing the timing, this gives much better throttle response on part throttle, and far better economy.
    Many people who tune engines disconnect the vacuum advance mechanism, and indeed on some distributors it is very hit and miss in operation and can cause anomalies in the timing. All in all however for a road engine, the vacuum advance retard should be retained if it is possible to do so (not always easy with sidedraught carbs). This will have a dramatic affect on economy and driveability especially on small throttle openings and when 'off-cam'.
    Why a modified engine requires timing changes
    A standard production engine has to run acceptably well over a wide range of operating conditions, poor fuel, towing of trailers/caravans etc. and yet still deliver good economy and flexibility. Consequently the engine is tuned to give good low down performance and will use conservative timing and fuelling settings. It also has to cope with poor quality fuel and changes in altitude that can seriously affect the engines behaviour.
    A tuned engine generally is not designed to give good performance below 2500-3000 RPM and indeed below this level, the volumetric efficiency of the engine is seriously affected. The more extreme the cam profile, the worse this situation becomes. This means that the effective cylinder filling at lower RPM is poorer than with a standard engine.
    As explained earlier, in these conditions more ignition advance is required to overcome the slow burning of the mixture. If this advance is supplied by retaining the standard distributor and simply increasing the static timing, then the overall advance will be too high by the same number of degrees, this is obviously undesirable and can wreck your carefully modified engine. Not increasing the static advance however will lead to a very sluggish engine until quite high RPM is reached.
    The engine speed at which maximum advance is reached also needs to be earlier for a tuned engine, say 3500-3800 RPM, on a standard engine maximum advance may not be reached until much later, say 4500-5000 RPM. This means that both the amount of advance, and the rate at which it is applied will not be satisfactory in a modified engine if the standard distributor is retained is unmodified condition.
    Establishing static advance requirement
    The static advance requirement for a modified engine is very much dependent on the duration of the cam fitted. Below is a table of advance requirements and expected idle speeds for a range of cam specifications. ON NO ACCOUNT use these settings before the maximum advance on the distributor has been correctly limited.
    Cam duration Advance Idle speed expected
    270 10-12 600-800
    280 12-14 900-1000
    290 14-16 1000-1100
    300 16-18 1100-1200
    310+ 18-20 1100-1400
    When establishing static advance the golden rule is never use less than 10; never use more than 20 degrees. The engine may well tolerate more than 20 degrees at idle, but the moment the throttle is opened and cylinder filling is improved it will pink heavily. One problem often encountered when using more static advance than standard is that the engine may 'kick-back' when starting causing the starter to slow dramatically, this can be confused with a flattened battery or duff starter motor. You may need to compromise by the odd degree or two if your engine will not tolerate the required degrees of advance at start-up.
    Static advance implies a measurement taken when the engine is stationery, however it is usually set at idle in order that any latency in the distributor drive gear is taken up. A rough setting can be made when the engine is still, but it MUST be set at 1000RPM or lower with the vacuum advance disconnected so that any latency is taken up and the centrifugal advance has not yet started its operation.
    Establishing maximum advance requirement
    Notwithstanding the compression ratio and other factors, the characteristic that determines the maximum advance setting is the shape of the combustion chamber and the position of the spark plug. Below is a table indicating the desired maximum advance for the various common combustion chamber shapes.
    Chamber typeExampleMax AdvanceSemi-Hemispherical Jaguar/Lotus Twin cam 40-44Carotid/heart B.L. 'A' Series,'B' series34-35Bathtub Pre Xflow34-36Bowl in piston Xflow 35-37Closed Pinto 38-40Wedge Imp 36-38Open Wedge Rover V8 36-38Pent-roof 4 valve Vauxhall16v ,Zetec,Cosworth YB, K series 30-32
    Note how little advance a four valve, pent roofed combustion chamber needs, this is because of the very short and equal length flame paths from the centrally placed plug promoting a very fast burn. Engines with a faster burn time have a much higher RPM potential, the faster the burn, the less advance requirement, and therefore the fewer problems at high RPM. This is why Grand Prix engines have many small cylinders; these have small combustion chambers that have very fast burn times, allowing much higher RPM than engines with fewer large cylinders.
    Below is a chart showing the typical and ideal advance requirements for a modified engine, the engine speed at which maximum advance should be reached is 3500-3700RPM, advance should start at around 1300RPM and be all-in by this figure
    How to go about modifying your advance
    Now we have established what the static and maximum advance should be, we should think a little about how we go about measuring advance, modifying the distributor and setting the timing.
    First of all you cannot correctly time an engine without a strobe/timing light of some kind which is reliable, you cannot correctly time an engine without markings on the pulley to establish where the various engine positions are, E.G. Top Dead Centre (TDC) and various positions before this. The most critical position is the maximum advance setting that should NOT be exceeded.
    To achieve this the engine pulley needs to be marked at TDC (most already are), at the position for desired static timing (between 10 and 20 degrees depending on cam) and at the maximum advance position. The most satisfactory method I have found is to accurately draw the pulley on a sheet of card, then using a protractor draw the appropriate marks on the circumference of the pulley template. If you have a PC, use a drawing package to accurately draw the circumference of the pulley and the degree markers rather than doing this by hand. Remember that if the engine rotates clockwise (most do) that the static and maximum advance positions will be further round the pulley in a clockwise direction from the TDC marker.
    These marks need to be transferred to the engine pulley. This is most easily done by removing the pulley and marking its circumference from the template by filing a small slot or groove where each these marks need to appear. Then fill these slots on the pulley with tippex or similar white paint. You may also wish to mark the 20 and 30 degree positions, simply ensure that you can tell these apart from the other marks then refit the pulley. Make sure you check and double check where you are going to mark before doing so; do the job only once and do it correctly.
    Establishing the existing advance
    To begin the timing exercise you must statically time the engine at around 10 degrees BTDC. With the engine at 10 degrees BTDC on the firing stroke align the distributor so that the points are just about to open or in the case of an electronic distributor so that the stator and rotor tips are just aligning. Lock the distributor enough to stop it moving. Ensure that the vacuum advance retard is disconnected and the tube plugged. Start the engine and let it idle, adjust the timing with the engine running to 10 degrees BTDC and lock the distributor.
    Now increase engine speed until it is around 5000 RPM and hold the engine steady - this ensures that all the centrifugal advance has come into operation. Use the timing light to see where the maximum advance is currently set. If it is not in line with your mark, adjust the timing carefully until it is, remember most distributors turn in a clockwise direction so you must turn it in an anti clockwise direction to advance the timing, and a clockwise direction to retard it. Ensure it is set at the maximum marker at 5000RPM and lock it into position.
    Now allow the engine to idle and examine the timing again to see what setting you have for static timing, this should be easy to estimate from your markings. Write this setting down. If you then subtract this static setting from the maximum setting this will give the degrees of mechanical advance that the distributor currently supplies.
    Example
    Maximum setting 38 degrees, static setting 10 degrees (38-10) = 28 degrees supplied.
    We have now established how much advance the current distributor gives and can move on.
    Establishing mechanical advance requirement
    We have our desired static and maximum advance figures already calculated, so now we can use the same simple formula to establish how much centrifugal advance we need from the distributor.
    Maximum advance 38 degrees, required static advance 18 degrees (38-18) = 20 degrees required.
    In our example the standard distributor is designed to give maximum advance from a starting point of say 10 degrees of static advance, if the maximum advance required is 38 degrees, then it's range is 28 degrees (38-10), this means that if the static setting is increased to 18 degrees, then the total advance will be 46 degrees (18+28), way too much. It is unlikely that the standard distributor will give the correct amount of advance, it will usually give too much. This is why we must restrict the total centrifugal advance that the distributor is capable of supplying to our new figure, in this case 20 degrees, then with the static setting of 18 degrees, the maximum advance will be 38 degrees (18+20), the correct figure.
    If the advance supplied is MORE than required, and this is highly likely, it means as expected that the distributor is supplying too much mechanical advance, and that the stops in the distributor must be bent to restrict the travel of the mechanism. If the advance supplied is LESS than required which is unusual, then the distributor is supplying too little mechanical advance and the stops must be bent/filed to allow more travel of the advance mechanism.
    TIP
    As the distributor must now be removed from the engine it is a good idea to turn the engine to near the static timing position to assist refitting, you may also find a scribed line on the distributor body which should align with a mark in the centre of the rotor arm heel. This is also an aid to refitting.
    Modifying the distributor to limit advance
    To alter the amount of advance, it is necessary to remove the baseplate from the distributor to expose the centrifugal mechanism below. On some distributors, notably the Sierra one, which is a magnetic reluctance type this is a tricky and delicate operation, the rotor is held in place by a small pin in the shaft of the distributor, which must be removed before the gubbins and base plate can be removed, note carefully how the thing came apart before working on the advance mechanism. Some baseplates need turning in relation to the distributor body in order to remove them, notably the BOSCH type as fitted to Ford engines, note which way the base plate was turned and how it fits back together very carefully.
    Once the baseplate has been removed grasp the drive gear/pin in one hand and turn the end of the shaft with the other (oo-er). It should be possible to establish how the centrifugal system functions and how to limit the advance. By taking in to account the current advance supplied and the desired advance, it should also be straightforward to work out how much restriction is required and then bend the stops which limit advance in the appropriate direction to achieve this.
    Standard distributors have the rate of advance controlled by two springs attached to the centrifugal weights. The two springs are usually of different tension and length. Frequently the heavier of the two springs is not actually under any tension when the distributor is stationary, however the weaker of the two should have absolutely no slack when stationary. If the lighter of these two springs does have some slack, it is important to take this up so that the spring is under slight tension otherwise the timing settings will be altered immediately the engine turns over. If there is no tension in the spring, bend the stop on that spring to re-instate tension.
    On some distributors that do not use stops which can be bent to change total advance it may be necessary to add material to slots or to pins. Do not be tempted to do this with materials such as araldite or filler, it will simply drop off or wear out, metal must be added, either via a dab with a MIG, or little braze. I have used small metal sleeves in the past (small pieces of tube) to increase the size of pins etc. Those of you equipped with Pinto engines have a very conventional distributor that uses stops that can be bent very easily.
    After the advance has been limited it is time to refit the distributor and retime the engine as detailed previously. Hopefully the required advance will now have been obtained, if not then repeat the procedure above until the total advance on the distributor is correct. This can be a little tedious if it needs several goes to get this right, PERSEVERE; it is well worth doing.
    TIP
    When fitting the distributor it is often quite difficult to get the drive teeth/oil pump drive etc. to line up correctly, it is sometimes a good idea to turn the engine over slightly by hand backwards or forwards until the various drives engage, then the engine can be turned back to the static setting again.
    Establishing the Correct rate of Advance
    In most applications for performance engines, the heavier of the two distributor springs requires replacement with a lighter spring. Alternative springs can be gleaned from a scrap distributor (it does not need to be of the same type necessarily) from a breakers yard. This is necessary to give a faster advance ramp, as seen in the previous table.
    When the heavy spring is replaced by a lighter one, BOTH springs must be under tension, but not under too much, there must be no loose rotational movement between the central shaft and the weights as this will give too fast a ramp and lead to pinking. The static timing, if set as before is plenty, and we do not want any more until around 1300-1500RPM. If the distributor does not have bendable posts that allow the spring tension to be varied, then the springs may need to be tweaked a little to shorten or lengthen them.
    Once you have substituted a weaker spring for the stronger one, it is time to check the rate of advance. Re-assemble and refit the distributor, and set the static timing to the required amount of advance. Set the idle at between 900-1000RPM. Hold the engine at 1000, 1500, 2000, 2500, 3000 and 3500RPM and note the amount of advance at each RPM. If maximum advance is not reached at 3500RPM, gradually increase the RPM until maximum advance is reached and note the RPM. This is usually a two-man operation.
    Plot the rate of advance on some squared paper, alongside the ideal advance ramp shown in the previous table. If the advance springs are too weak then maximum advance will occur at considerably less than the 3500RPM ideal setting. If the springs are too strong then maximum advance will occur well beyond this setting. To be safe, the springs should prevent maximum advance being reached before 3500RPM.
    If the advance ramp starts before 1300RPM, then this indicates that the initial tension on the springs is insufficient, so it will be necessary to bend the posts to increase initial spring tension. By bending posts to increase or decrease initial tension it should be possible to make the advance ramp very close to the ideal which is a steady increase in advance between 1300RPM and 3500RPM. The highest acceptable RPM at which maximum advance should be reached is 4000RPM, the lowest is 3200RPM. Do not exceed these limits.
    When you are happy that the rate of advance is near to the ideal (this will be after some trial and error) it is time to road test the car. Try accelerating in each gear from around 1500RPM and see if the engine pinks (pings), if it does note the engine speed at which this is happening, and double check the advance at this speed. It may be necessary to increase the spring tension a little to restrict advance at this engine RPM.
    Most engines will pink a little if given unreasonably low RPM and a high loading, so if this only happens at 1500RPM in a high gear, this is an unusual combination and is unlikely to be encountered in normal driving. When the rate of advance is correctly set it should give the engine a rock solid idle, strong progression and mid range performance.
    Well.. That's all there is to it.
    If you have properly followed the procedures outlined in the previous text, then the advance curve for your modified engine should be very close to ideal and you should be able to feel the difference in your engines performance. If you are in doubt, exercise caution, better too little advance and slightly tardy performance, than too much and a ruined engine.
    Points type distributors
    If you are using an early distributor that uses points, you are probably aware of the problems that can be caused, points bounce, arcing at the points, timing scatter. As the points wear, the timing tends to retard significantly, and the dwell setting goes all to hell.
    As a replacement for points I can strongly recommend the IGNITOR unit that can be bought from Aldon Automotive, Europa or Demon Tweeks, this is a completely self contained electronic ignition trigger (Hall effect) and amplifier all in a single unit that fits neatly inside the distributor as a direct replacement for the points. It requires no black boxes, or separate amplifier, and only requires a power feed from the plus side of the coil to be fed into the distributor with the switch wire. Because it is a rotary device it is not affected by clapped out distributor bearings either. It is also ideal for classic cars where its self contained design renders it undetectable from outside the distributor. Fit this unit and forget it, it requires no maintenance and is ultra reliable. It is relatively inexpensive compared to normal electronic ignition systems such as Lumenition.
    I used an IGNITOR on my old Pinto engine that used to eat points. The starting was much improved and the timing stayed perfectly set for many thousands of miles.
    Dave Andrews
  2. The Following 9 Users Say Thank You to Dave For This Useful Post:
  3. #2
    Racer 4drmatt's Avatar
    Jun 2007
    Bedford
    2,079
    69
    Re: Ignition Timing for Modified Engines
    Nice one
    Spanner Monkey R-40's Avatar
    Jun 2007
    fife
    206
    second that nice one
  5. #4
    Wiltshire
    Site has been move to here:
    http://www.dvandrews.co.uk/
  6. The Following 2 Users Say Thank You to Varnish5000 For This Useful Post:
  7. #5
    Dave's Avatar
    Oct 2003
    Cheshire
    19,588
    141
    Even better. Thank you
    It's an excellent site, with loads of very good info.
  8. #6
    boXXer
    Guest
    ive used it a few times, well handy
  9. #7
    9,204
    Quote Originally Posted by Dave View Post
    far too much too get lost, im v.happy its been moved.
    dave andrews is a very helpfull guy , very much in the t.s. spirit. it is his info on porting the zetec head that i posted in the zetec section.
  10. #8
    Ireland
    3,579
    173
    I used this info to tune a couple of distributors now, it works a treat!
    I got huge improvements in power as compared to an off the shelf dissy "supposidly set up to suit a modified engine" with 290 deg rally cam, bought from a well known company.
    I modified that timing chart so I could print it out and use it to help me map my distributor timing, very handy to compare your results and see where you need to make the changes.
    Sorry if it's too big lol
    Jason
  11. #9
    Ireland
    3,579
    173
    Here is an example of a dissy map for a 2.0 pinto engine I recently built.
    Engine runs very well with this dissy, nice fast and clean throttle response.
    Jason
  12. #10
    4,889
    Hi, mine always look something like this:
    (borrowed your graph)
    Attached Thumbnails Attached Thumbnails modified_graph.JPG‎
  13. #11
    Ireland
    3,579
    173
    Looks like you are using a very weak primary spring and your secondary spring is coming on tension at 2k
    Full timing is coming in a bit late.
    Looks pretty good though.
    I use the lightest springs from std distributors, one with a little tension for steady idle timing and using a secondary spring with a slider U shape end coming on tendsion at about half dizzy advance.
    I also extend the two slots in the base of the dizzy drive shaft to allow for more ignition advance without hitting the end of the slots using a round file.
    Then bend back the advance stops slightly to get the desired full advance without the two pins in the advance shaft hitting the end of the slots in the dissy drive plate.
    All of the fine tuning can be done by removing the small cover plate towards the bottom of the distributor body and bending the spring posts or advance stops as required.
    I use an acurate rev counter placed in the engine bay, directly facing me while tuning so I can take acurate readings quickly with ease.
    Jason
  14. #12
    4,889
    Hi Jason,
    not alot of people know the ins and outs of distributors any more ...
    I bought and restored an old distributor-tester some years ago, saves me alot of time and hassle as you can check the advance at a certain rpm and vacuumlevel on the bench, see photo.
    For easy starting on high CR-engines (like my BDE) I sometimes use a static ignition timing of 0-2 degrees BTDC and a fast first advance curve starting at 500 rpm.
    Leon.
    Attached Thumbnails Attached Thumbnails bosch1.jpg‎
  15. #13
    Ireland
    3,579
    173
    I am thinking of building a simple dizzy testing machine since I have a few dizzies to modify soon.
    Could use a simple cord drill that turns in both directions with adjustable rpm using 400 to 2500 rpm (half crank speed)
    Using an old oil pump drive shaft to do the turning with a disc and adjustable pointer.
    A simple bracket to hold the distributor body from turning, a 12v power supply to coil, ignition module, rev counter, plug and plug lead, and a good strobe light with adjustable advance.
    Should work a treat.
    The only problem I noticed with using an advance that cranks at a low advance as you say in your bde is when the fan comes on the engine drops the rpm a little then the ignition advance drops a few degrees and you get a much lower tickover and the engine wants to stall when the fan is on.
    All the bd engines seem to not like starting, sometimes its a real bitch, love the rip of them tho.
    Jason
  16. #14
    Dec 2004
    Ireland
    1,781
    31
    There is an thread somewhere on turbosport that says that max advance should be fully in at the same RPM as max torque which would mean that the advance should continue up to nearly 5.5k rpm.
    Tom
  17. #15
    Ireland
    3,579
    173
    Quote Originally Posted by Group4_Mark2 View Post
    Tom
    I tried that before, had initial advance starting at about 1300 -1400rpm and all in at about 4.5k
    The engine didn't like it at all, far less power and very laggy, engine wanting to spit back through the carbs a bit because the ignition was so retarded.
    Jason
  18. #16
    Dec 2004
    Ireland
    1,781
    31
    I think that maybe what is needed is to have an initial advance of 16 degrees at 1400 which ramps quickly up to approx 36 degrees and then a slow advance from there to 5.5k with a max advance of 38 degrees.
  19. #17
    Ireland
    3,579
    173
    That sounds good although I think it would be difficult to achieve with a dissy.
    Jason
  20. #18
    Ireland
    3,579
    173
    Hi Jason,
    Leon.
    So do you aim to have a fast initial advance and then leveling off towards the max advance?
    I aim to have the advance faster as the camshaft gets wilder, fairly slow advance for a std engine and v fast for a race engine.
    And what rpm do you aim for max advance at?
    What are your thoughts on the max advance @ max torque theory?
    I wish I had your dizzy machine, very handy.
    Jason
  21. #19
    4,889
    Jason
    Hello Jason,
    for a dizzy without vacuum-advance I use a faster mechanical advance then std. With a std engine/cam the advance is not as much as with a full-race engine/cam. (as you said)
    With a dizzy you have not much variables to play with, just the max advance and two springs controlling the advance rate. So max advance will be at a certain rpm (say 4000) and above. For a programmable system however the theory is max. advance @ max torque. But the torque curve, especially with an engine with programmable ignition, isn't a simple curve. Because of carbs, inlet-track, exhaust, etc there may be more rpm's (!) where you have max torque.
    To be honest the dizzy is something from the last century ...
  22. #20
    Ireland
    3,579
    173
    One thing that never made sense to me when comparing a dissy 2d map to a 3d ignition timing map is the max advance at full throttle, (FT).
    As i understand it an engine needs maximum advance when the throttle is shut and you are at max rpm, when shifting down geras hard.
    This is because you get poor cylinder filling when the throttle is shut, and at FT the engine needs far less advance because the cylinders have much more fuel and air in them, so the burn time will be much faster and therefore you need less advance.
    For example an engine with a dissy might have 38* max advance from 4k onwards and if the same engine was running a 3d mapped ignition system it might only need 32* advance at 7k and FT to run best.
    So the dissy would be advancing the engine 6* too much at 7k and FT,
    how does the engine cope with the extra advance without pinking/detonation?
    Jason
  23. #21
    to get the best out of mapped ignition your find that in actual fact advance is usually less at peak torque( which is where its most efficent) than it is either side of it where the engines less efficent
  24. #22
    Ireland
    3,579
    173
    You have a good point Graham
    It makes sense that the max torque rpm would be the point where the cylinders have the most amount of fuel and air crammed in, so you need more advance both before and after that point to compensate for the reduced cylinder filling.
    That would mean a dizzy should have max advance just slightly after max torque rpm.
    After all this discussion it is becoming much more obvious why 3d mapped ignition is so much better at any rpm than a dissy will ever be.
    Jason
  25. #23
    Dec 2004
    Ireland
    1,781
    31
    Advance is also a function of RPMs and flame burn speed so I think that initial advance would finish before Max torque but advance would begin to increase after max torque to compensate for less complete cylinder filling and less efficiency after max torque.
  26. #24
    Ireland
    3,579
    173
    Yep
    Tough job trying to do all that with a dizzy lol.
    It is possible to get a dizzy's advance to start @1300 advance quick, reach 36*@3200 and 38* all in @4.5 or 5k by using a fairly weak primary spring doing all of the work up until the 36* when it hits a strong secondary slider spring which only lets the dissy reach full advance at much higher rpm.
    Jason
  27. #25
    if your used to dizzy advance curves then 3D managment advance curves look very scary,
    addmittidely its a turbo map but the current map in my ecu has 40 degrees inital advance!
    although by peak torque advance is down to 12 degrees and back up to about 20 degrees at peak power
  28. #26
    Nov 2009
    essex
    6,623
    338
    so if i've got this right say i have a pinto with a 260deg duration, i disconnected the vacume advance, start the car, let it idle at about 700 rpm and set the timing to about 11 degrees advance, then once done that, hold at 5000 rpm, say it then came up 38 degrees, i know i have 28degrees advance, (is that rght) then i reconnect the vacume advance and its done??????
    i've always let the rolling road do it all, and i did fancy having a crack at it myself, not so sure now.
  29. #27
    er no if you have 11 degrees of advance timed into the engine with the vac dissconnected and 38 dgrees @5000, you still have 38 degrees advance, what you have is a base setting of 11 degrees and 27 degress mechanical advance from teh dizzy, if you then connected the vac advance you would have even more adavance!
  30. #28
    Nov 2009
    essex
    6,623
    338
    so basically i need to set it all up with the vacume advance connected? sorry if its all mentioned but its such a vast quantity of words i keep loosing track of myself.
  31. #29
    generally for engines with vac advance you set them up (unless doing it under load on a rolling road) with the vac disconnected, then connect the vac, ignoring the effect the vac has on the timing,
    most carbed cammed pintos want about 10 degrees advance at idle vac off.
  32. The Following User Says Thank You to Graham For This Useful Post:
  33. #30
    Nov 2009
    essex
    6,623
    338
    that will be good enough, i'll do that then, seems odd to have a vacume advance if it works just as well disconnected
  34. #31
    Dec 2004
    Ireland
    1,781
    31
    The vacuum advance really only works under part throttle and closed throttle when there is a lot of vacuum in the inlet manifold. When the throttle is partially open the engine cylinders only partially fill so a lot of advance is needed to burn the mixture. The vacuum advance provides this extra advance. Under wide open throttle conditions the cylinder fills much more fully so a lot less advance is needed to burn the mixture.
  35. The Following User Says Thank You to Group4_Mark2 For This Useful Post:
  36. #32
    Nov 2009
    essex
    6,623
    338
    that makes sense because the advance is taken from below the throttle butterflys isn't it? so when at idle i would think thier is a lot more vacume in the inlet manifold then thier is at full throttle. how much more advance would the vacume add at idle then if i conncted the vacume after setting it at 10degrees with the vacume disconnected, would it add just 2 or 3 degrees or more like 8 to 10? i feel really thick on this subject
  37. #33
    4,889
    The vacuum-connection of the carb is above the throttle-butterflies if the engine is idling.
    When you open the throttle a bit the vacuum-connection is below the throttle-plate.
    So at normal idle there is no (or very little) vaccuumsignal to the distributor.
  38. The Following User Says Thank You to Miniliteman For This Useful Post:
  39. #34
    Nov 2009
    essex
    6,623
    338
    ah, i see, that makes alot more sense now , thank you everyone for your patience
  40. #35
    May 2009
    melbourne
    64
    So in a perfect world when you run mapped ignition such as megajolt what does the map look like for say a standard pinto?
  41. #36
    Dec 2004
    Ireland
    1,781
    31
    If you register on the forum you can download loads of maps for megajolt. There are a few for the pinto in different forms.
    http://www.autosportlabs.org/viewfor...0545066cbdcb7b
    You can read the maps using a text editor. The second row is the rpms, just add two zeros,
    The advance0 up to advance9 rows are the advances for different throttle positions or map values. The minimum advance is for wide open throttle.
    Tom
  42. #37
    Dec 2004
    Ireland
    1,781
    31
    A few maps can also be found here
    http://replay.web.archive.org/200808...lt/mapping.php
    This site is no longer live so this is only found on the internet archive
    Rgds
    Tom
  43. #38
    Mar 2007
    Hartwell
    166
    My old Droop Snoot RS 2000 was stock bottom end 10.5.1 group 1 head and cam twin 48,s this was running @ 12 at idle @ 38 max @ 3k , one of the best results i had was a Caterham i got a 15hp gain on a 1700 x/f running 40,s ect ect ended up with a solid 135 hp it drove fantastic and went like stink.
    A chap called Graham Hickman showed me the ropes over a 4 year perioed , inc a lot of dizzy mods so i ended up with a lot of small differnt strengh and lenght springs. We also welded up the bob weights adding and removing metal in various areas ect ect.
    Good intresting post....
  44. #39
    Jul 2003
    South Wales
    332
    Where can I send a dizzy to be done ?
  45. #40
    Dec 2004
    Ireland
    1,781
    31
    Have a word with Jason "rwd fords rule", He is very knowledgeable an may be able to help you out.
    Tom
