Results 1 to 14 of 14
Thread: Rear coilovers.... Avo or Gaz, what do you reccomend??
    Dec 2010
    oxfordshire
    153
    As title, avo or gaz, i need to get some i can actually adjust the stiffness of!!
    Mechanic beeRS's Avatar
    Apr 2007
    Chelmsford
    773
    114
    Re: Rear coilovers.... Avo or Gaz, what do you reccomend??
    I have a pair of old (10+ years) Avo on the back and Gaz on the front. They are so similar, that if you peel the logo sticker off they look like they came out of the same factory. They are both old units, so I cannot comment on their newer stuff.
    Dec 2010
    oxfordshire
    153
    Ive heard that gaz have got better, they have about 36 adjustments on bump then avo have about 22. Just hoping someone with some newish ones can comment!
    Bodger scoobymike's Avatar
    Oct 2014
    south wales
    62
    176
    haven't long bought these. Have used them before on various road / rally cars. Gaz are good for about any choice of suspension setup. These are going on my rwd mk6 fiesta.
    Oct 2015
    Essex
    347
    33
    Road or track ? My Gaz front rears are hard on even the lowest setting unless u use at least 250lb F and 185lb R springs
    I’ve tried rates from 130 lb to 185lb and strangely it’s better ride stiffer the rear spring 🤔
    Dec 2010
    oxfordshire
    153
    Quote Originally Posted by Ianbavs View Post
    I’ve tried rates from 130 lb to 185lb and strangely it’s better ride stiffer the rear spring ��
    They will be going on my starlet outlaw hotrod on the ovals. The rear springs i run are near 200 anyway
    Dec 2010
    oxfordshire
    153
    4,899
    Quote Originally Posted by slatter View Post
    You don't need 22 adjustments let alone 36!
    Tried both for a very short time on the tarmac rally car but concluded these are not rally parts.
    Went for AST dampers after that. But this was also years ago.
    May 2004
    Norn Iron
    1,143
    Protech ?
    http://www.protechshocks.co.uk/
    I used to run AVO until adjusting one day, the adjuster fell out along with all the oil in the shock. The Protech are far superior quality !
    Dec 2010
    oxfordshire
    153
    Protech ?
    I had a look at them, but couldnt see any for escorts with rear turrets??
    May 2004
    Norn Iron
    1,143
    They'll build whatever you want. Give them a call, tell them what you need, what fittings top/bottom, open/closed lengths etc etc and they can do.
    Dec 2010
    oxfordshire
    153
    Will give them a ring, thanks!
    Dec 2011
    Cowdenbeath
    400
    32
    Protech ?
    Pro tech shocktec gas avo all buy there valves and adjusters from the same places
    May 2004
    Norn Iron
    1,143
    Quote Originally Posted by Turboman View Post
    Well other than both knobs being round, there were no similarities between my old Avo's and the Protech in use. Avo's were single adj, Protech dual adjustable if that might matter.
    The quality in feel of the clicks, ease of adjustment on the Protech's far superior than the Avo's ever were, even when new. And also different numbers of clicks. The Avo's were more prone to the adjuster tightening up or difficult to turn, whereas the Protech's always seem to be nice and easy.
    And so far the Protech's havent fallen apart and give no indication of doing so.
    I had a few Avo's on my car over the years, largely as they were easy to buy from with good choices online. But I had a few because I had to replace units through issues.
    The Protech's have just been better for me all round, only found out about them about 4-5 years ago.
