Opinions on Std Pinto Weber inlet manifold.
Any views on Std ford type Wber pinto inlet manifold.
I have noticed several types some have two seperate tracts from carb but others one big hole.
https://www.ebay.co.uk/itm/Weber-Inl...MAAOSwZqZaN-8P
https://www.ebay.co.uk/itm/Ford-2-0-...cAAOSwhQhYzZQH
Wondered if anybody has ever flow tested one and if so are they any good?
Re: Opinions on Std Pinto Weber inlet manifold.
i think all the 2.0 ones are open. have a read of grahams modded one in the carb section.
A modded one.
Sounds interesting.
I will do a search.
Hi all,
I can't seem to find Graham's thread describing modifications to an inlet manifold for a 32/36, could someone please post a link to it?
It's a sticky I think in carb sections it's about 32 36 Dgav mods.
the one with twin holes will be for a very late pinto using a dmtl carb, i cant see that having any advantage over the normal 2.0 manifold, in fact i would think it worse.
