Results 1 to 3 of 3
Thread: How to: water temperature sensor
    Oct 2017
    Bussum, The Netherlands
    30
    My thermostate house has no temperature sensor. I have ony a cylinderhead sensor.
    I need 2 temperature sensors. 1 for the ecu and 1 for the dashboard meter.
    The standard Ford sensor is pushed in, has an O ring and a clip to keep it in place.
    I have seen another thermostate house where the temperature sensor was pluged in form underneath.
    Is there a way to get it in?
    Is there a difference for the bottom and the top part position? see arrow on the picture.
    Thanks in advance for your answer.
    Attached Thumbnails Attached Thumbnails IMG_1248a.jpg‎
    IMG_1249b.jpg‎
    Clint's Avatar
    Jul 2001
    925,804
    Re: How to: water temperature sensor
    What ECU are you using, if you have not purchased one yet then we can drive the dash direct from a Link ECU, so you only need one sensor, and the CHT sensor is more than adequate to do both, it is just not so accurate below 40C and measures up to 280C, if you need to fit an ECU sensor it must be in the flow of water when the thermostat is closed.
    Oct 2017
    30
    Maybe I Will Connect the CHT sensor to a dash gauge. Exciting. Who had that?
    still nu question remains. Van I fit avsensor in niet current sensor house?
    Zetec 2.0i
