xe conversion parts
c20xe steel big wing sump, zero install comes with baffle plate and pick up pipe, has been trimmed for a big simpson or tle manifold
£150
also have wcxm with lowered rack mounts and towers removed which was fitted with above sump but only goes if sump sells
£100
c20xe steel flat flywheel with a used helix 4 paddle plate which ideally needs relining 228mm 22splines
£150
Dry sump tank, for under bonnet installation brand new never fitted or used comes with fabrication cut out panel and securing strap, dash12 male fittings
£250
will do package deal if any interest
Re: xe conversion parts
Any pictures of the dry sump tank? I already have the mount so what's your best price for just the tank?
really want to sell them as a pair, easier to sell that way
Any pictures of the tank though?
If you look at the ralloy website its one of thiers
Also have some budget steel rods with L19 rod bolts 143mm long £150 posted
Jenvey DCOE inlet manifold ero degree install, has had a repair but done properly £100 posted
Is the big wing sump still available?
had someone interested but not heard from him for about a week
Pm'd about the jenvey dcoe inlet manifold.
dry sump tank sold
tank cut out panel sold
paddle plate sold
items still for sale.........
C20xe steel rods 143mm
world cup xmember lower rack mounts with towers removed for chassis mounting
C20xe steel flywheel
jenvey inlet manifold for zero install
mk2 escort bias pedal box, converted oe pedal box with cylinders with provision for hydraulic clutch
