RS Turbo in trouble!
can anyone tell me why my RS has started to judder when i put my foot down and the turbo kicks in? the battery has been playing up, but is being replaced tomorrow. the problem stops when i restart the engine, but comes back if i put my foot down again!! any ideas as to what this is? ? any help is appreciated!!
Re: RS Turbo in trouble!
Sounds like some kind of overboost problem?
ok, think that is worth a try, sounds promissing! When i brought it the bloke said the boost was turned up! If any1 has any other ideas it would be greatfull. I will get it to the garage. Not got a idea how to turn it down. Thanks.
Has it got a boost gauge fitted? Also has it got a bleed valve fitted?
If yes to both then a) see what boost its making, to be safe you want it to be low at about 12psi untill you can get the car set up properly as you dont know what the chip is mapped for!
b) use the bleed valve to wind the boost down. Failing that take the actuator rod off of the little ball thing on the wastegate on the turbo and make sure the preload is half a hole, ie with the actuator rod resting on the ball thing, you can see half of the ball in the hole in the actuator rod, then you just pull the rod a little on the spring to get it to go over the ball.
Here we go, it has a boost gauge fitted n is showing nearly 14 psi on boost! Far 2 high! But where would the bleed valve be? If it has one? Thanks for this help mate, its all good learning.
14psi is not a lot, it all depends what the chip is written for. I dont know much about rst's so dont know what the standard boost should be, i would guess around 8-12psi without searching? A bleed valve could be anywhere depending on the last owners choice! It should be somewhere on the hose between the actuator and the inlet/compressor housing of the turbo in that hose, if it has one. They may have just wound the actuator rod up to achieve the boost though!
The Following User Says Thank You to dangerousdave For This Useful Post:
Thanks again mate, run out of light 2day but will have a look hopefully one night in the week. Pulled up some info on the boost, getting the idea it needs to be round 7-8. Think i will aim for that till i can get it in diagnostic test.
Nice one, thats the best you can do is to aim to get the boost to a standard level then see what it goes like and if the problems still there or not, if it isnt then you know its a boost problem, then just either wind the boost back up until it starts doing it again and back it off a touch, or better still get it in for a proper set up by your local tuner (is northampton motorsport the site sponsor close to you?)
try again when you have new battery my cossie had same fault kept holding back under load turned out to be my alternater not charging stopped the fuel pump working propely when the battery got low
The Following User Says Thank You to capri s For This Useful Post:
Ha, funny you should say that!!! I have had a few test done by a friend that has a garage, he found the fuel pump is low on pressure and thinks it could be a pipe in the tank off the fuel pump or the pump its self. on tick over the battery is reading 14.2volts but doesnt seem to get better when i rev the car or turn the lights on etc? Still has 13.4 with all battery eatting equiptment on! This should be enough?
Chargingis fine and the rs turbo has'nt got a pipe in the tank it graverty fed only the fiesta turbos have in tank pumps and the pipe splits on them internaly though.
It is a fieata RS turbo. So guess the split pipe is looking to be the cause? when the problem occurs it does correct it self when left to tick over or when the stopped and started again. Its all pointing to split pipe, dam well have to get the tank out.
tank is easy to come out on a fiesta what happens is the seal goes weak and the pipe slides down and lets air in hence loss of presure, so take it off and put a rubber pipe in its place because you cant buy the original one it comes with the fuel pump only.
The Following User Says Thank You to joe GSM For This Useful Post:
Top man thanks for the help, gona get it out next weekend hopefully.
