Help needed!
I have just purchased a set of Mk1 Escort Roll top seats. They have been completely refurbished and new covers fitted. They were not brand new just unused so i cannot go back to the seller, neither do i want too.
Sadly when i got them home i realised that the side latches on them were not operating correctly and only one cable is pulling well enough to release the hook that would allow the seat to tilt forward.
I tried hours of adjustments on the cable adjusters but with no luck so i have been forced to remove the back cover to see what is going on.
Basically the far cable is not tight enough or routed well enough to pull the release mechanism so i was hoping someone could shed some light on how it should be as i it is not obvious.
Any help would be appreciated
Regards Stuart
Sent from my SM-G950F using Tapatalk
