Results 1 to 2 of 2
Thread: Managment for RV8 Turbo
    Mechanic Slymanrs2's Avatar
    Jun 2004
    South London
    629
    I'm looking to use a 4 barrel carb setup for pressure/turbo use, along with rising fuel rate regulator.
    What is the best advance/retard control box to use with a carb/blower setup?
    I know the carb setup works, but have looked at the fuel injection setups and it looks very complicated as not many people specialize in turbocharging setups on the V8's.
    So what is needed to make the carb setup work well?
    any other ignition, controls needed?
    Escort Mk1 Cosworth YBT build.
    Dec 2008
    West Sussex
    109
    Re: Managment for RV8 Turbo
    I guess you ride a bike so you understand modern technoligy. Forget carbs etc it will only leave you a jibbering wreck in the corner or a dark padded room looking to swat invisible flys. Go EFI, with most all the other AWDC guys its easy I do lots of them. A DTA S60 system is easy to tune and adjust and used by many on these motors from tuners like J.E Motors etc.
