Spec:
2.0 Zetec engine block (silvertop)
86mm(1,5mm oversize) wiseco 12.5:1 comp ratio 2050cc
Eagle rods
lightened and balanced standard crankshaft
Focus ST170 Head
ported
three angle valve job (factory valves 33,5mm and 28mm)
CatCams 293/285 degres with 12.7/12.2mm lift
Exhaust
factory Focus ST170/SVT header heat wraped
3" exhaust
intake/injection
hayabusa throttle bodies enlarged by 2mm
Megasquirt ECU
440cc injectors
cooling
Davies Craig electric water pump with controller
First dyno session fuel maps and minor ignition timing tuning. Cam timing, ignition timing and trumpet lenght adjustments to come.
For now:
269.9HP@7500rpm and 261Nm(192.5lb/ft)@6150rpm
