Re: 105E ANGLIA 1.6 OHC build
Seam sealer when you're done and a good sealer paint.
Will Doo...still not fully finished ...will post the end result
cleaning the right chassie leg and having the crossmember mounted like factory.....next step is to replace the lower section with some fresh metal
All the rust is from the salt coming off the ocean?
@ langia.... no , just rainfall , condensation n poor patch jobs ,actually I got the car with all chassie legs and door sills packed with rust to the brim ,the car was a bit of a storage bin for junk by the previous owner .......I'm exposing all chassie legs and getting everything firm
like a dog were getting to the bone =) #chassiework
Some Christmas cleaning ,looking like a complete chassie rebuild
at this rate I'll need a cut off wheel sponsor lol ....#fredflinstone
The jacking points look horrible
more rust in these critical areas
an in-depth look
more muck
it's going to be a complete chassie job so I added in some braces and left a little extra on the ends so I can lift the body or move the car around / put it on stands
im thinking with all this work to be done ,maybe I should start a YouTube series like urchfab aka the mongrel build .....if anyone would like to see the build more in depth pls comment....I'll try n get some videos going
Season greetings to all the mates in the forum......I've been spending the holidays steady in the red dirt drilling spot welds etc n cleaning up some muck as we head into 2020 ........my biggest goal is to have a solid foundation
after a bit of tlc
Just a little white to keep it from oxidizing more while I work
It got late so couldnt get any good photos of the left side.....but I also removed the inner section which was also rust filled
Originally Posted by
alladdin i dont see any pics ?
I see them. But they're too big, they take an age to load they need down sizing really...
I'm. Not.sure how.to.have it done ...I am using the turbosport uploader
Windows has a photo resizing tool. So resize them with the windows tool then use the uploader as you have been doing. I can't remember off hand what the optimum size you want is though.
