Mk2 Escort XE
"7 Degrees= these
(Stubbys in pic 3 for sale!)
Xe +
48's, Cams,Forged Pistons, CHD Head, SBD Manifold, ARP's, Modded Manta sump.
Just waiting for the oil pick up pipe.
Re: Mk2 Escort XE
What pistons, rods and cams you using?
Re: Mk2 Escort XE
Std Rods with modified caps, Std Forged Pistons, 1612 cams, ARP rod and flywheel bolts......and a full spec Head!.
Just a basic rebuild somewhere around 200 horsepowers, see how it goes, while I save for the SCCR Box, steel rods, high comp pistons and SERIOUS cams.
Will thrash this round over the summer, then build the High Power unit over the winter
Re: Mk2 Escort XE
looks class im doing the same i've 4 XE's so one in the escort now and then build myself a 2.3 monster from one of the others over the year!!!
Re: Mk2 Escort XE
How are you thinking of building a 2.3?
Re: Mk2 Escort XE
frontera block with XE head Tom Casey over here has built some
Re: Mk2 Escort XE
I thought there were problems with the vibration dampers on the crank with them?
Re: Mk2 Escort XE
Thats what I am looking at. 2.3ltr turbo block as it doesn't have the dampers. Or look at trying to source a 2.4ltr vortec block from the states, as used in forklifts etc. http://www.gm.com/experience/technol...Industrial.pdf
