Results 1 to 40 of 40
Thread: Various Drawings for Escort parts
    Jan 2007
    Weston Super Mare
    1,039
    77
    As my Escort is finished and I will soon be selling it I thought that I would share the information I have gathered whilst building it in the form of some very usefull drawings.
    Hand brake cable brackets: to suit MK1 or MK2 Escort with cossy calipers and using a Sierra cable.
    MK1 Escort lower door repair panel#
    Cossy fuel pump and filter brkt
    Hose clamp / seperator for fuel lines inside of car
    Atlas - Cossy caliper bracket
    Brembo front caliper to RS2000 Bilstein bracket
    3 bolt Roll cage forward hoop bracket
    Roll cage hoop clamp
    Bucket Seat mount (tube style)
    I have some others like door cards for MK1 escort that I will dig out.
    Hope this helps someone else and saves them the time of re-drawing them, or you may have trouble sourcing some parts like I did.
    I might be able to point some of you in the right direction of a good cheap fab shop if needed.
    Attached Files Attached Files
  2. The Following 17 Users Say Thank You to Cyco For This Useful Post:
  3. #2
    Jan 2007
    Weston Super Mare
    1,039
    77
    Re: Various Drawings for Escort parts
    Next lot:
  4. The Following 8 Users Say Thank You to Cyco For This Useful Post:
  5. #3
    Jan 2007
    Weston Super Mare
    1,039
    77
    Last 2 for now:
  6. The Following 5 Users Say Thank You to Cyco For This Useful Post:
  7. #4
    Jan 2007
    Weston Super Mare
    1,039
    77
    You can see the hose clamps used in this pic
    Attached Thumbnails Attached Thumbnails 24102008239.jpg‎
  8. The Following User Says Thank You to Cyco For This Useful Post:
  9. #5
    Jul 2006
    bristol
    10,882
    892
    Nice one bud come in usefull for a few poeple I would think.
  10. #6
    Apr 2004
    Bangkok, Thailand, Thailand
    4,346
    479
    Good Stuff
  11. #7
    Dec 2007
    Dubai
    1,678
    29
    Excellent, will use your seat mount diagrams, ta much
    www.gulfpetrolheads.com
  12. #8
    Jan 2007
    Weston Super Mare
    1,039
    77
    Bracket for holding a cossy ECU under the dash board where the heater should bolt to the heater bowl.
    Will post the drawing in a bit.
    Attached Thumbnails Attached Thumbnails ECU holder.jpg‎
  13. #9
    Jan 2007
    Weston Super Mare
    1,039
    77
    Center console for Mk1 Escort.
    Note the overall height dimension may vary depending on what tunnel you have fitted.
    Also change the DWG file to suit your own logo or user name.
  14. The Following 2 Users Say Thank You to Cyco For This Useful Post:
  15. #10
    Jan 2007
    Weston Super Mare
    1,039
    77
    Quote Originally Posted by Cyco View Post
    Drawing for ECU Holder and heater bowl blank (needs to be sealed in place)
  16. The Following User Says Thank You to Cyco For This Useful Post:
    Dan
  17. #11
    Jan 2007
    Weston Super Mare
    1,039
    77
    Fuel tank Base to suit rectangular tank with Swirl pot.
    This is to suit a MK1 escort.
  18. The Following 2 Users Say Thank You to Cyco For This Useful Post:
  19. #12
    Jan 2007
    Weston Super Mare
    1,039
    77
    Gearbox mount plate to suit MK1 escort to Cossy T5 using a standard Cosworth mounting rubber.
    Note you will have to drill the holes to suit your brackets in the top wings.
  20. The Following 2 Users Say Thank You to Cyco For This Useful Post:
  21. #13
    Part of the furniture Decade Plus User Ratters's Avatar
    Mar 2004
    Bristol
    8,648
    75
    nice one si
  22. #14
    Jan 2007
    Weston Super Mare
    1,039
    77
    I have some more as well.
    28 drawings so far, didn't realise I had this many custom parts done for the Escort!
    Escort MK1 door cards to come along with heater bowl hearder tank.
    Sure I have a MK1 strut brace somewhere as well, altho these are cheap enough to buy.
  23. The Following User Says Thank You to Cyco For This Useful Post:
    Dan
  24. #15
    Dan's Avatar
    Aug 2006
    north london
    4,378
    115
    thought you deserved a few thanks for all these
    very handy for anyone wanting to remake stuff
  25. #16
    Jan 2007
    Weston Super Mare
    1,039
    77
    Cheers Dude!
    You are right tho, these drawings will make it very easy for anyone else doing an Escort with a Cossy motor.
    Some of the parts will suit other install's as well.
    Hand brake bracket's and ECU holder for example could not be sourced when I looked.
    This is some good information for free, use it people should save you plenty of time and money.
    Cyco
  26. The Following 2 Users Say Thank You to Cyco For This Useful Post:
  27. #17
    Oct 2004
    get me on my beeper,beeper
    11,882
    this would be a good sticky,well done cy
  28. #18
    Jan 2007
    Weston Super Mare
    1,039
    77
    See you at Coombe mate.
    Can't wait to see you thrashing that yellow beast around, it is looking Sweeeeet!
  29. #19
    Jan 2007
    Weston Super Mare
    1,039
    77
    Swedish Inlet Plenum for Cossy Turbo
    Throttle bracket to suit inlet to follow.
    Attached Thumbnails Attached Thumbnails cmh-k20015 throttle brkt.jpg‎
  30. The Following User Says Thank You to Cyco For This Useful Post:
  31. #20
    Jan 2004
    South Africa
    3,354
    20
    WoW - thanks
  32. #21
    Spanner Monkey robvirgo's Avatar
    Mar 2002
    Cork , Ireland
    251
    10
    best post ive seen in a while.did you make the parts yourself or pass drawings to a firm.
    rob v
    Rob Virgo
    Cork
    Ireland
  33. #22
    Jan 2007
    Weston Super Mare
    1,039
    77
    Quote Originally Posted by robvirgo View Post
    rob v
    I passed the drawings to a firm, I just do the design work and the drawings.
    I tend to use the same companies for all my fabrication and machining work as i know the quality is good.
  34. The Following 2 Users Say Thank You to Cyco For This Useful Post:
  35. #23
    Dec 2007
    Dubai
    1,678
    29
    What discs and calipers are your Brembo brackets designed to work with
  36. The Following User Says Thank You to dobuy For This Useful Post:
  37. #24
    Racer Decade Plus User savvi's Avatar
    Jul 2009
    Oxfordshire
    3,032
    110
    Ecellent thread, as said one of the best i've seen on a forum for a while, even though they take a few minutes to download
    Don't suppose you did anything on fitting a Zetec at all ?
    I'm just in the process of collecting the parts and some i want to make myself or get an engineer mate to do for me due to the prices
  38. #25
    Jan 2010
    Birmingham
    26
    Much Love, been looking for diagrams to do my mk1 up with =]
  39. #26
    Nov 2008
    Adelaide, Australia
    1,331
    96
    Cyco. As others have said...a big thank you!
    Did you ever find the door card drawing?????
  40. #27
    Bodger tarquin's Avatar
    Jan 2009
    South Africa
    137
    9
    Did you manage to find the door card drawing ? As would be very handy
  41. #28
    Mar 2002
    Cork , Ireland
    251
    10
    Bump for door card drawings...
    Cheers again
    Rob Virgo
    Cork
    Ireland
  42. #29
    Jan 2007
    Weston Super Mare
    1,039
    77
    Hi Yes I have found the drawing.
    I just need to convert it to pdf tomorrow as I dont have solidworks at home.
  43. #30
    Jan 2007
    Weston Super Mare
    1,039
    77
    MK1 ESCORT FRONT DOOR CARD AS REQUESTED.
  44. The Following 2 Users Say Thank You to Cyco For This Useful Post:
  45. #31
    Jan 2007
    Weston Super Mare
    1,039
    77
    I cant seem to upload a PDF file for this one, if anyone else can I will email it to them.
    Cyco
  46. #32
    Tyre Kicker nrmmendes's Avatar
    Feb 2011
    Portugal
    36
    30
    This is a quite nice Thread!!!
    Thanks for Sharing
    Can you tell me if the Door card drawing you posted here can be used on a Mk2 Escort.
    I'm not aware of the difference between Mk1 and Mk2 doors...
    Thanks!
    NRMM
  47. #33
    Bodger Vonky's Avatar
    Nov 2010
    Germany
    63
    12
    Hi there,
    Can anyone Sketch some escort mk2 rallye mudflaps for a forrest Arched car with measurements here? Would be Great. I would like to Cut them by myself, since 140 pounds is quite a Lot of Money for those moulded flaps!
    Cheers helge
    non-native speaker! Cut me some slack!!
  48. #34
    Nov 2013
    france
    75
    103
    a proper build it yourselfer excellent td,s
  49. #35
    Sep 2014
    Melbourne, Australia
    Howdy all,
    I am after the drawings for the watts linkage boxes for group 4 Mk2 Escort. Can anyone help?
    Thanks in advance.
  50. #36
    Jan 2015
    Sverige
    32
    This is a really good thread, but it would be great with some dxf or dwg files.. instead of pdf drawings. if its possible?
    Thanks!
  51. #37
    Jan 2014
    Launceston, Tasmania, Australia
    31
    15
    great thread thanks heaps
  52. #38
    Feb 2008
    London, England
    157
    Excellent work
  53. #39
    Bodger Richb77's Avatar
    Jan 2018
    Outside Berlin, formerly Newmarket Suffolk
    22
    A little while ago i asked for dimensions of the fuel pump blanking plate for the crossflow engine. I couldnt find any information so bought one. I have drawn it up for anyone else that may wish to make their own or custom one. The PDF is 1:1 printed on A4.
    Click image for larger version Name:	XFLOW_FuelPump_Blank.jpg Views:	292 Size:	99.5 KB ID:	83317XFLOW_FuelPump_Blank.pdf
  54. The Following User Says Thank You to Richb77 For This Useful Post:
  55. #40
    Sep 2022
    Coleraine
    30
    Do you need dwg drawings created ?
