Results 1 to 10 of 10
Thread: jetting for single 45 dcoe on lynx / pinto 2.0
    9,200
    i know this is a can of worms but just looking for a ball park starting point - maybe someone already been there got a tee shirt.
    single 45 dcoe (152G?) spanish 4 progression hole. lynx type manifold, 2.0 pinto std to 140 bhp range.
    it has 36mm chokes which i would like to leave in, 4.5 aux also.
    thanks in advance
    Mar 2012
    2,118
    Re: jetting for single 45 dcoe on lynx / pinto 2.0
    Mine was standard engine, was working fine with 160 main 155 air F16 50F8 but was 5 prog holes. This way it gave average max power. I'm not saying this would have been the most perfect setup but was OK for me to compare max power against 40 DCOE and DMTL setup.
    So should be a good starting point.
  3. The Following User Says Thank You to Dyno For This Useful Post:
    9,200
    Thank you Dirk
  5. #4
    4,888
    160 main jet, 180 air, F2 or F3 tubes, 55F6 idle.
    And check floatlevel as these can be a bit off out of the box.
  6. The Following User Says Thank You to Miniliteman For This Useful Post:
  7. #5
    9,200
    cheers Leon.
  8. #6
    Mar 2012
    2,118
    I would advice, check float level and all the rest of the carburetor because nothing is correct with these new Webers out of the box !!!!!!!
  9. #7
    9,200
    its not a brand new carb, its one of a pair that have been used - other damaged.
    and since you both mention it - what is the correct float setting for these ? up and down. thanks .
  10. #8
    4,888
    I set these at 12mm .
  11. #9
    9,200
    at closed ?
  12. #10
    4,888
    at closed ?
    Yes, with lip just touching the ball inside the needle valve. With gasket in place.
    As Dirk wrote if it's a new carb check it over, I always clean them ultrasonic as well before fitting.
