Results 1 to 10 of 10
Thread: Perspex windows MK2
    Feb 2007
    cornwall
    103
    Perspex windows MK2
    Has any one fitted one piece polycarbonate windows to rear doors on 4 door MK2 Escort, any details on fitting, pics, was wondering if to increase thickness due to size, thanks
    Oct 2012
    Bristol
    Re: Perspex windows MK2
    Yes did this on mine using 6mm polycarbonate. Started by cutting a template from card then used a jigsaw with a fine blade to cut it out. Tried numerous ways of fitting it but ended up with the bottom edge "inside" the door using the window seal clips to hold the base then bolting and bonding the rest using M4 buttons and sikaflex. Then I bonded some rubber extrusion on to cover the bolt heads etc. Finished the inside off with a strip of wood covered in carbon film shaped to fill the gap and make it look better! Couldn't think of a better way..
    Can't get this old iPad to upload pics but can email some if it helps
    Oct 2012
    Bristol
    Still no luck sorry :-(
    Feb 2007
    cornwall
    103
    Hi, Thanks for help and description, a picture would be very helpful, if you can upload would be grateful, thanks
    Oct 2012
    Bristol
    Feb 2007
    cornwall
    103
    Thanks for the pictures, you must be the only person to have done this, Your car looks very clean, thanks again
    Feb 2007
    cornwall
    103
    25,110
    most people use 4mm thick, which is msa minimum thickness allowed
    Oct 2012
    Bristol
    Sorry all just spotted the typo I used 5mm polycarbonate
    TURBOSPORT SPONSOR Turbosport Sponsor brafferton's Avatar
    Apr 2007
    york
    70
    207
    We make a polycarbonate window kit for the Escort four door.
    Stuart.
    Airedale Race Components.
    0113 2509852
    http://www.raceplastics.com
