Anyone got a set of 93mm piston for a Pinto build?
I have a set of Woosner pistons connected to Cossie rods. They are in good nick and were replaced last year with longer rods and shorter pistons. Cameron Gilmour does my engine builds and I kept them as spares.
Pm me for price
No problem
You are going to need a stroke of 80mm to get 2172cc with 93mm pistons, how are you going to achieve that, by offset grinding the crank and using Diesel rods? If I were you I'd rather go for a set of forged pistons and Cosworth rods than std ones. Then at later date you could put a decent head and cam on it and go for serious power.
if you use x/flow rods you wont have to shorten the piston at all, in fact you may need to deck the block a bit
Interesting read.
If using an offset grind crank and 1.6 Fiesta Diesel Rods, what forged 93mm pistons are recommended?
Thanks in advance.
