Results 1 to 7 of 7
Thread: Pinto specs.
    Oct 2015
    Southampton
    35
    86
    Pinto specs.
    Just setting up a couple of engines, does any one know valve lift at TDC for a standard 2.0 cam?
    Also the same info for a Camtech CT26 723.
    I don’t have the tools to dial in using full cam timing with the disc.
    25,099
    Re: Pinto specs.
    std cam, simple just line the dots up with the engine at tdc, the std cam is so mild it really wont be fussy about timing
    Oct 2015
    Southampton
    35
    86
    Pinto specs.
    Running a standard cam (rules are rules) on not a very standard engine. Head and block skimmed so wanted to dial in the vernier on the standard cam to maximise performance. But if it’s not that fussy then I won’t bother.
    Any idea on the other cam? I have this info but don’t have cable lift at TDC which is the only way I know how to time 😵
    25,099
    Re: Pinto specs.
    if you dont know where to time a cam, time it to give equal intake and exhaust lift at tdc you will be very close, if your chasing top end power you might be best off running slightly more intake lift, ie time it with 80% exhaust compared to inlet. ie 1.0mm inlet lift 0.8mm exhaust, that is only an example i dont know what valve lift at tdc a standard cam has but i would guess teh figures would be about double my example
    Re: Pinto specs.
    Quote Originally Posted by Tabblink View Post
    Any idea on the other cam? I have this info but don’t have cable lift at TDC which is the only way I know how to time ��
    The only way to time the above cams without a timing disc is to use the overlap method on no1 cylinder. You'll need an accurate DTI gauge to do it this way. Set both inlet and exhaust valves open by the same amount of lift. You can then experiment by giving the inlet a little more opening for more advance if required.
    Oct 2015
    Southampton
    35
    86
    Pinto specs.
    Cheers guys. I’ll give that a go.
    Oct 2015
    Southampton
    35
    86
    Pinto specs.
