Page 2 of 2 FirstFirst 1 2
Results 41 to 64 of 64
Thread: How to increase your oil pressure
  1. #41
    Re: How to increase your oil pressure
    Quote Originally Posted by rs_brammer View Post
    Just a bit of advice, i'm replacing the spring in my pump and just wan to see what is the most effective way of removing the current plug from the pump?
    Many thanks
    see 1st post of the thread!
  2. #42
    Nov 2003
    Wirral UK
    6,740
    257
    What he said ^
    http://escort.accelerator.org
  3. #43
    May 2011
    new zealand
    47
    you will need to drill a small hole in the block on the crossflow engine to feed a little more oil to the cam dizzy / oil pump drive to prevent wearing of drive on cam which causes lots of lash in your dizzy eratic timing
  4. #44
    Jan 2004
    South Africa
    3,354
    20
    Sorry I missed much of the last replies,
    RWD I can see the lip.
    Trust me I've done 4 pumps like this (Ford pumps) and just about everone that I know that races pinto's here does it.
  5. #45
    Mar 2007
    Hartwell
    166
    Turn the cap down or mill up a thinner one to sit in , thus stiing further down the body.
  6. #46
    Quote Originally Posted by DarthVader View Post
    its probably a case of in SA although still ford the engines had pumps from different suppliers which were made slightly differently
  7. #47
    Jan 2004
    South Africa
    3,354
    20
    Could well be,
    I just did a pump for my motor last week, I have a spare that has some bad wear on it, I might just cut it open and have a look inside.
  8. #48
    Mechanic Turbosport Subscriber ebenech's Avatar
    May 2010
    Montevideo, Uruguay
    495
    61
    Hi mates, it's me again, now with a query about oil pressure on my 2 ltr Pinto engine. Despite I'm going to do to my std oil pump all what RWD ford rules described, thank you, I have experienced today this situation:
    I started up the engine with the std pump and I obtained 45 psi at 2000 rpm and 80º C., which is correct. Now I changed the oil pump for a hi pressure one - Kent manufactured - and my new pump gave me 45 psi at idle and 80 psi + at 2000 rpm, temp always 80º C. Isn't that too much ?
    I'm worried about what will happen when my engine will be at 6000 - 7000 rpm.
    Can anybody give me a little of his expertness about this matter ?
    Wait your kind advices.
    Cheers,
    Eduardo
  9. #49
    i'd see if the pressure goes higher still with more revs it may not, if it doesnt dont worry
  10. #50
    Ireland
    3,579
    173
    Sounds like you fitted a high volume high pressure pump? some of the pumps have very strong pressure relief valve springs, if the oil pressure goes over 100psi cold it will have to be looked at, don't worry about 95 to 100psi max cold with thick 20w50 oil it won't hurt the engine, you only need about 60psi hot oil pressure for any pinto engine, race, rally, drag, turbo whatever
  11. #51
    May 2010
    Montevideo, Uruguay
    495
    61
    Ok Graham, thanks for your kind reply. I assume then that 80 psi is Okay, isn't it ?
  12. #52
    yes i'd say 80's ok, i'd be starting to worry at over 100
  13. #53
    May 2010
    Montevideo, Uruguay
    495
    61
    Thanks you too RWD ford rules for your kind advice. The pump I purchased is marked as high pressured only, not high volume also; I purchased it to Rally Design and they offer both types, and for the price I paid it should be high pressure only. About oil, I'm using full synthetic 5W40, so that's why I'm surprised about the high figures I'm obtaining in the manometer. By the way, the std oil pump I took away from the engine, is going to be fully transformed according to your tutorial at the beginning of this thread, thank you.
    Cheers,
    Eduardo
  14. #54
    Oct 2009
    Finland
    119
    30
    Quote Originally Posted by Svein View Post
    Burton xflow uprating kit from the Good Old Days
    Hmm...what is that cap on the left for?
  15. #55
    Ireland
    3,579
    173
    It looks like the end cap to hold in the spring, the other one looks like an oil pump to block locating dowel on the right
  16. #56
    Oct 2009
    Finland
    119
    30
    Yep.
  17. #57
    Nov 2013
    france
    75
    103
    The Mellings M68CHV seems the right one for our pinto,s ! Am i right ?
  18. #58
    Dec 2004
    Papa New Ginea
    67
    12
    Ported as instructed rotor height to the pump body clearanced to .001 end plate surfaced and 3.2 mm shim under the spring. Should sealer be used under the pump end plate on reassembly?
  19. #59
    NO defiantly no sealer
  20. The Following User Says Thank You to Graham For This Useful Post:
  21. #60
    Mar 2012
    2,118
    Quote Originally Posted by Roger Miller View Post
    Yeah but ..................
    it could be done I don't like it, looks not too reliable, but hey...
    You'd be best to get the US style pumps with the center pin support, real hi volume and leave the alloy bodies for recycling
    Very old, but what oil pump could this have been? Standard Ford engine or uprated part? Would be the most perfect Pinto oil pump
    Pictures did not came over but visual in the first page of this topic
  22. #61
    Tyre Kicker Willi's Avatar
    Germany
    Do you mean the Melling M86B? Still available at Rockauto, bought two some month ago .
    https://www.rockauto.com/de/parts/me...,oil+pump,5564
  23. #62
    Quote Originally Posted by Dyno View Post
    its a melling M86b oil pump, a bog standard replacement oil pump. to be honest its all a pinto needs. For oil pumps i usually search out origonal NOS ford pumps but they are getting hard to find.
  24. #63
    Mar 2012
    2,118
    The big pump with double bearing, larger rotors is not Melling M86b. The left on, small rotor is. I also use Malling M86b and is the same size as the standard Ford pump but cast iron. It better as standard but the on on the right should be perfect, large rotors end double bearings
  25. #64
    Germany
    Oh right, you're absolutely right, you can actually see an HV pump in Roger Miller's picture. Did an M86BHV ever actually exist?
    I always use M87HV on my Cologne V6 engines, the pumps are very similar to the HV pump in the picture, larger rotor then stock and double bearing. Highly recommended for the early Cologne V6 in my opinion.
