Results 1 to 6 of 6
Thread: water cooled turbo
    Dec 2013
    Cumbria
    19
    water cooled turbo
    hi guys,just on with my yb powered mk1 escort the cooling system i am using does not have a header tank(also coolant return for the turbo) i know there is 2 outlets on the thermostat and one of them is for the coolant feed to the turbo,where could i connect the other line which would have originally gone to the header??thanks in advance guys
    Nov 2010
    Australia
    170
    12
    Re: water cooled turbo
    I have the water line coming from the side of the block (drain plug) to the lower side of the core. The core should be on a slight angle to promote thermo-syphoning. The higher side plumbs to the thermostat housing. I highly recommend a silicone top hose from thermostat housing to radiator. I initially used an OEM rubber hose which bloated up from the hot turbo water
    Nov 2010
    Australia
    170
    12
    Click image for larger version Name:	36701877_10156489002432359_63457089531412480_n.jpg Views:	64 Size:	87.1 KB ID:	82983
    Nov 2010
    Australia
    170
    12
    Better pic here Attachment 82984
    Nov 2010
    Australia
    170
    12
    Click image for larger version Name:	36726427_10156489004317359_6172958990469693440_n.jpg Views:	54 Size:	100.9 KB ID:	82985
    Clint's Avatar
    Jul 2001
    933,379
    OE turbos that use thrust type bearings are best to not water cool on a Mk1/2 - Under engine bay temps are greatly reduced by not running water.
    Aftermarket turbos that use ball bearings require water cooling.
