Results 1 to 3 of 3
Thread: Weber DGV32/32 on 1100 Valencia
    Feb 2018
    Blaricum
    For a lightweight Fiesta mk1 I'm preparing a 1100 Valencia engine. It has a flowed cylinder head with hardened valve seats and a special inlet manfold for a Weber DGV32. Will post some pictures soon. The carb has 21 & 24mm venturies and has been jetted for the engine, just not sure about the 2nd stage aux. venturi. It currently has a 3.5 (same as the 1st stage) and it looks to be fine. Would a change to a 4.5 make a difference?
    4,888
    Re: Weber DGV32/32 on 1100 Valencia
    No.
    Feb 2018
    Blaricum
    Cheers Leon,
    It should be fine then, I just leave it as it is.
