Results 1 to 9 of 9
Thread: Carb Problems
    Racer 4drmatt's Avatar
    Jun 2007
    Bedford
    2,079
    69
    Carb Problems
    I fitted a different carb (from a p100) to my engine today but it starts, but won't run below 1500 rpm (going by the original clocks, but you can tell it's fast)
    It just splutters and cuts out. The carb was a bit seized at first but eveything is moving freely now.
    Here's how I've connected everything up. Could be all wrong as I don't really know what I'm doing
    There is a sensor (or at least that's what it looks like) in the center of the top pic... What is it for? Is that needed?
    I assume that the heater hoses need to pass through the carb for some sort of cold start mechanism? The way I did it is that the pipe comes from the heater and into the top one. the bottom one then goes to the inlet manifold. Have I connected this up right?
    Is there something blatenly obvious that I've missed/done wrong? The carb was sold as unknown condition, so could be that... I'm not sure it is though.
    Sorry for all the questions, but it's doing my head in lol
    4,889
    Re: Carb Problems
    Hi, whenever I see such a carb I get sick .... whoever invented that should be sh*t.
    However that carb has an electric anti-diesel valve to stop any petrol going into the engine whenever the ignition is off.
    To test, get a piece of electric wire and run it from the + of the battery to the terminal you thought was a sensor. You should hear a "click" whenever the electric connection is made or disconnected.
    Now try again if the engine is running okay on idle with the extra wire. If it is, you should run a wire from the ignition to this connection. Grtz, Leon.
    Dave's Avatar
    Oct 2003
    Cheshire
    19,588
    141
    Re: Carb Problems
    Get a proper carb and stop arsing about with that crap.
    32/36 DGAV is best, but you will need a different manifold too.
    Jun 2007
    Bedford
    2,079
    69
    Re: Carb Problems
    I feared that would be the answer
    Anyone got one for sale that I could collect today?
    Jun 2007
    Bedford
    2,079
    69
    Re: Carb Problems
    cheers
    Apr 2009
    wendover
    99
    11
    Re: Carb Problems
    Hi Mate i think i have a 32/36 DGAV on a pinto manifold, call me on 07842581674 and i will av a look. Im in Buckinghamshire, but if i find it u can cum get it 2day.
    Jake
    Jun 2007
    Bedford
    2,079
    69
    Re: Carb Problems
    Quote Originally Posted by no1escortfan View Post
    Jake
    Cheers. I'll give it another couple of hours trying to get it running as it is. If I get no joy I'll drop you a PM or give you a call also how much would you be after?
    I support TS Decade Plus User
    Scott_B's Avatar
    Sep 2003
    ESSEX
    2,291
    47
    Re: Carb Problems
    I have got a new diaphram for that piece of shite VV carb if you want it matt, but do yourself a favor, get 10L of petrol, take it off, burn it, hit it several times with a big hammer,throw it in a big hole in a field and bury it,
    Thatll give you much more satisfaction that you will ever get from diving with it and you will save yourself a lot of time.
    Racer Decade Plus User mk2escortmadman's Avatar
    Apr 2004
    Canewdon, United Kingdom
    2,001
    Re: Carb Problems
    Frank
