Page 4 of 17 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 LastLast
Results 121 to 160 of 656
Thread: My New Project ( Millington Escort) to stop me using this
  1. #121
    Spanner Monkey genRS2000's Avatar
    Jan 2009
    Perth Western Australia
    67
    438
    30
    Re: My new Project to stop me using this
    Filler, filler and more filler . Sanding, sanding and more sanding
    First I blended in the front arches and the spoiler extension.
    Then the dents were filled.
    Next I cleaned all the old sealant and glue from the door and window openings. While I was doing that I removed the old stripes with a heat gun and scraper.
    ( and much rubbing with a turps soaked rag to remove the glue ).
    Now it is all wrapped up so I can sand the original paint without getting dust on the inside. Then it will be time to apply the coats of primer.
  2. #122
    Nov 2008
    Adelaide, Australia
    1,331
    96
    making great progress
  3. #123
    Jan 2009
    67
    438
    30
    Yes Glenn, soon it will be painted. A mate knows an ex spray painter and he has agreed to come over ( he is only 5 minutes away) to spray the final coat when I am ready for a reasonable price
    I have ordered a fibreglass bonnet, boot lid and front and rear bumpers....
    and the big thing... I have ordered an engine. Hopefully it will be ready in a month.
    Did some work on the Atlas today:
    fitted the oil surge reducers
    and because I have changed the calipers I need to make new mounting brackets, so it is out with the MDF again.
    I will do a drawing from this template and have them laser cut.
  4. #124
    Jan 2009
    67
    438
    30
    More work on the Atlas:
    I had to work out how to attach an anti roll bar to the axle housing.
    The kit I bought was meant to be attached vertically to the normal Gp4 link brackets but as mine is different this wouldn't work.
    This is the RH mount. I think that how it is attached is that 2 holes would be drilled in the link bracket so that the round threaded inserts would go into the bracket and the plate welded in place.
    I couldn't do this with mine so I turned the plate around and cut half the length of the inserts off and drilled out the ally mount so that it would sit flush on the mount.
    THe LH side was easier as there was enough room for the mount with with a couple of extensions welded onto the link bracket.
    It all worked out very well.
    Here is the bar in place, it faces to the rear and the uprights attach to the chassis rails.
  5. #125
    Jan 2009
    67
    438
    30
    Back to the body.
    Time to etch prime all the ally bits.
    More masking for the wheel arches and the engine bay
    These sticky dots are to stop paint clogging up the allen key holes in the arch and spoiler bolts.
    Last time I sprayed etch primer it came out of the gun with a cobweb effect so I asked the guy who is going to do the final coat and he said it could have been to thick so this time I added a bit more thinner.
    I don't no whether that was the cure but this time I had no problems.
    More goodies have arrived.
    Alcon front brake kit
    4 Piston differential bore calipers
    267mm vented discs
    The kit didn't come with pads so I spent ages looking at the different compounds available in the Pagid range.
    Chose these because they are a nice Ford blue
    But seriously I hope the RS5 compound will be the correct choice for my situation.
  6. The Following User Says Thank You to genRS2000 For This Useful Post:
  7. #126
    Jan 2009
    67
    438
    30
    Getting pretty fed up with working on the body. I am not a perfectionist but I like to do things properly so I want to get the bodywork right before spraying the primer.
    After moving it outside , I can see a lot of imperfections in the body: pinholes in the filler, scratches, lumps and bumps etc.
    So it is more filling and sanding
    Something to cheer me up
    My bespoke front suspension is nearly ready. I ordered it a couple of months ago and progress has been slow but looking at the photos the guy making it has sent me it will be worth it.
    Picked up my laser cut rear caliper brackets today.
    A bit of fettling and they will slip onto the stub axles ready too be welded on. Need to drill and tap the mounting holes first though.
  8. #127
    Nov 2008
    Adelaide, Australia
    1,331
    96
    Blimey! You are getting right into this build!
  9. #128
    Nov 2003
    Wirral UK
    6,740
    257
    Filling and sanding is soul destroying all right, I don't know how the bodyshop guys do it for a living. I would be slitting my wrists!
    Front suspension looks very cool though
    http://escort.accelerator.org
  10. #129
    Jan 2009
    67
    438
    30
    Decided to take a break from the bodywork and finish the rear caliper brackets.
    Finally the Atlas is ready to go to the man with the TIG.
  11. #130
    Pit Crew Hoogi's Avatar
    Jul 2008
    Lancashire
    1,590
    Very interesting Rear Axle/Suspension set up................very nice.
    The extra work on the body will be worth all the effort in the long run.
    Lovely looking MKII
  12. #131
    Jan 2009
    67
    438
    30
    I had pretty much given up on the bodywork but after reading this:
    Quote Originally Posted by Hoogi View Post
    Lovely looking MKII
    I thought I had better have another go at it.
    I did some more filling and sanding until I was finally satisfied with the result, after all this is a race car and not a show car.
    Then I sprayed 2 coats of primer.
    There are spots that I will have to redo after sanding it because I had to spray it in my closed shed which wasn't ideal.
  13. #132
    Jan 2009
    67
    438
    30
    I have been waiting for some decent weather ( it has been the wettest October since 1999 here) to finish the primer coat so in the meantime I have put the doors on a diet
    A complete door weighs a ridiculous 26kg
    I cut most of the internal panel out which made getting the window and its winding mechanism out really easy.
    I initially left the section where the handle mounts but later cut it out but I will put some of it back as I want to retain the handle.
    The intrusion bar mounted in the door weighs 4kg so that came out.
    A bit more weight loss .... swiss cheese
    An aluminium panel will cover the hole.
    And the final result is ... 11kg
    That will increase slightly when the plastic window and the closing mechanism go back in but it is still half the weight of the original door.
    Other news...
    the fibreglass bonnet , boot lid and bumpers have arrived.
    all the components for my engine are laid out on the engine builder's shelf ready to be assembled, hopefully it will be built this week.
  14. #133
    Jan 2009
    67
    438
    30
    Finally finished the primer coat and rubbed it down. I have removed the old masking paper so I can put fresh paper on so it will be ready for the ex-spray painter to put the final coat on.
    New front struts. These are from Gartrac with the lower part machined from a solid billet.
    News from 2 suppliers today... my Atlas axle has been set up and is ready to pick up and the bespoke front suspension is finished and ready to be shipped although I am still recovering from the final cost . It does look fantastic though.
  15. #134
    Mechanic helinelly's Avatar
    May 2010
    merseyside
    710
    insparation or what......imagine hour many hours you have put in just on the photos..lol.........anyhow absolute awesome build..love the arch spacers and work of art axel.............going to jump on mine now this week..need to get her on the spit...thanks for all your pics regards nel
  16. #135
    Nov 2008
    Adelaide, Australia
    1,331
    96
    When you removed weight from the doors did you happen to measure the weight difference at each stage? Do you happen to know how much weight was removed just by cutting out the metal behind the door card (your first photo)??
    Fabulous work as always....
  17. #136
    Jan 2009
    67
    438
    30
    Quote Originally Posted by helinelly View Post
    Taking the photos is easy... uploading and the writing up is the hard part
    I have periods of disenchantment with the build, so I keep thinking about the end result ( and buy new goodies for it )
  18. #137
    Jan 2009
    67
    438
    30
    I was only interested in the final result so I didn't weigh the difference at each stage.....
    but just for you Glenn I have now
    the first cut 1kg
    window 2kg
    1/4 window 1 kg
    complete intrusion bar 4 kg ( I don't think your Mk 1 has these ???)
  19. #138
    Nov 2008
    Adelaide, Australia
    1,331
    96
    Quote Originally Posted by genRS2000 View Post
    Just checked and mine (both the original doors and the spare set) and there is no large intrusion bar such as in yours just a 40mm wide U-Channel across the door width.
    Mine weigh in at 19.5kg
    Thanks for taking the time Bevan.
  20. #139
    Jul 2005
    Australia
    149
    Only the Aus built Mk2's had the intrusion bars - it may have only been the later models following ADR introductions.
    My 1980 Mk2 RS2000 has them.
    I had a brand new NOS mk2 coupe door which did not have the intrusion bars fitted so this was either an import or from an early run.....
    Paul
  21. #140
    Nov 2008
    Adelaide, Australia
    1,331
    96
  22. #141
    Spanner Monkey Luke's Avatar
    Sep 2006
    392
    Very nice build going on here. I think you have just set my doors on a holy future
  23. #142
    Jul 2009
    Perth, Australia
    112
    Luke/Glenn: Check the CAMS rule book first - it very common here for them to remove trims on our winning rally cars to check for "illegal" lightening - admittedly historic rally/race maybe different.
  24. #143
    Jan 2009
    67
    438
    30
    Put a bit of weight back in so I can mount the original door handle.
  25. #144
    Jan 2009
    67
    438
    30
    Aluminium panels to replace the door cards complete with cut out for the handle.
  26. #145
    Jan 2009
    67
    438
    30
    I have got sidetracked from the doors as I want to mount the alloy rear spoiler before painting the boot lid.
    The problem to be solved here is that the spoiler doesn't sit flat onto the boot lid making it difficult to mount it neatly.
    After a lot of I decided to make some brackets that will be riveted to the spoiler and bolted to the boot lid.
    Here is the prototype bracket
    This appears to work OK so I will make some more tomorrow.
  27. #146
    Jan 2009
    67
    438
    30
    The best laid plans.....
    After spending all morning making these brackets
    they aren't any good
    When I mounted the spoiler I wasn't happy with how it sat on the boot so I threw them away and did some more
    I then discovered that I could bolt the top of the spoiler directly to the boot lid using the same countersunk bolts as I used for the arches.
    The spoiler is slightly deformed around the bolts but it looks worse in the photos than it really is.
    Then I had to work out how to bolt the bottom part on.
    I used some of the plastic I had for the arch extensions. I cut 2 wedge shaped pieces which were bolted to the boot lid to make a vertical surface to bolt the spoiler to.
    The bolts screw into the plastic as with the arches.
    I had to move the bolts further up the spoiler so that there would be enough depth in the plastic for the thread but I had already drilled the LHS holes so I will have to fill them.
    It now fits well with the 8 bolts holding it firmly onto the boot lid. I will probably add a bit of Sikaflex when it finally fixed on.
  28. #147
    this is a top thread. Loving the look of that front suspension can't wait to see it delivered.
    Well done so far
  29. #148
    Jan 2009
    67
    438
    30
    Well done so far
    Me too but unfortunately it is sitting in FedEx's warehouse in Sydney because the paperwork has gone missing and the custom's clearance can't be done
    This is the kit before it was sent
  30. #149
    Nov 2008
    Adelaide, Australia
    1,331
    96
    mmmmm shiney new stuff
  31. #150
    Jan 2009
    67
    438
    30
    Yeh. I just wish it was in my shed and not in FedEx's
  32. #151
    Nov 2008
    Adelaide, Australia
    1,331
    96
    I received some shiney stuff of my own today. GRP4 Fab must love me!!!
  33. #152
    Jan 2009
    67
    438
    30
    They have had quite a lot of my money too.
    Still sidetracked. This time with the front towing point.
    I was going to mount it in the centre then I changed my mind but now I have changed back to the centre. Trouble is I now have messed up my shiny new paint so it will need patching up.
    I made the towing eye from an old sumpguard.
    Finally got back to the doors. I thought I had finished with filler
  34. #153
    Spanner Monkey QuIcKrAcK's Avatar
    Jan 2007
    LONGFORD IRELAND
    204
    [QUOTE=genRS2000;1808176]
    Holy smokes dude!!
    Thats mad
    Good mad though
    1700cc MK1 ESTATE DONE. MK1 2DR STARTED
  35. #154
    Jan 2009
    67
    438
    30
    After some frantic phone calls, faxes and emails I finally managed to get the paperwork to FedEx and I now have my very expensive front suspension kit.
    This increases the track by 20mm each side to match the increase in the rear track. I did not expect it to be a "work of art' , the quality is very impressive.
    As can be seen from the photos in the previous post by QuIcKrAcK it was made on a jig to measurements I supplied to the builder.
    Steering arms that have been made to minimise bump steer.
    Billet alloy TCA
    Compression strut
    Assembled arm with the compression strut to body bracket
    Anti roll bar
    Anti roll bar mounting brackets.
    Now it is back to preparing the doors, bonnet and boot for priming. Hopefully I will get that done in the next few days.
  36. #155
    Nov 2003
    Wirral UK
    6,740
    257
    Very nice !
  37. #156
    Jan 2005
    up north
    670
    very nice some top quality bits going on there,its the same as what ive done on mine but i just knocked it up out of some steel tubing,if you get the rear comp strut joint in line with inner tca strut will travel on an even arc,are you running 15s or bigger
  38. #157
    Jan 2009
    67
    438
    30
    Quote Originally Posted by turbospud View Post
    I am old fashioned... I like my Escorts on 13s
    Sprayed some primer today
    Tomorrow I hope to spray the white top coat on the insides of the bonnet , boot and doors and then I will leave the outsides for spray painter.
  39. #158
    Jan 2009
    67
    438
    30
    Sprayed the insides of the bonnet, doors and boot lid today . My spraying is getting better but still have some orange peel. There is a very fine line between applying enough paint to minimise orange peel and applying too much and getting runs.
    I have freshly masked the shell and it is now ready for painting.
  40. #159
    Nov 2003
    Wirral UK
    6,740
    257
    Ain't that the truth! I always end up with runs
  41. #160
    Jan 2009
    67
    438
    30
    Time to paint the Atlas.
    Coat of primer
    While I was waiting for the primer to dry I started on the fuel tank.
    I had 2 pieces of aluminium laser cut with holes for the filler, level sensor and opening for the in tank pump in the top piece and a hole for the drop pot in the bottom.
    These will be bent and welded together to form a rectangular tank.
    I bought 2 brackets to go inside the tank so that the top plate can be bolted on.
    Stopped work on the tank and sprayed the top coat on the Atlas.
