Time to start on the brakes.
I spent a couple of hours trying to decide where to mount the brake/clutch fluid reservoirs. It meant putting the bonnet on and crawling( hoist is being installed next week ) under the car and getting into the engine bay to check clearances and various postions.
I finally made the decision to mount it in the middle and made up a cardboard template to make a bracket.
Folded up a bracket from ally.
Looking good
Grommets in the firewall for the fluid inlet hoses. The hose is 9/16" OD and the grommets are 1/2" to get a tight fit.
Next up was the pedal box. The Gartrac one I have has a 7/16" balance bar and the adjuster I have has a 3/8" thread so I had a adapter made from nylon to join them. Being made from nylon the fit is very tight allowing the bar to be turned both ways without unscrewing.
