as title, i'm searching a pair of cosworth N/A YB cosworth cams complete with solid lifters and if there are also the double valve springs i'm interested too. Text me what you have.
cheers!!!
cheers!!!
I got some Kent Cams with profiles L1 / BD3 which were removed from my N/A cossie when I went to injection.
Also 16 hydraulic lifters with the hydraulic part removed (to make them work the same as solid lifters), 16 double valve springs and 8 valves. Not sure if the valves were from the inlet or exhaust, but I remember they were shortened BDG valves.
The lifters are marked E1-E8 and I1-I8 to describe where they were fitted in my head, so they can be kept in the same positions relative to the cams.
Let me know if these are any use to you.
Gavin
A long shot but are these still available?
