I support TS
Re: Type9 gear lever
The 4 speed RS has the big nylon not to screw it in, so that'll be a 5 speed one.
And a quick shift too by the looks of it
Just bend the handbrake to one side and it should clear
That's definitely a T9 one, you can still get the plastic bush (that goes in the fork at the bottom) from ford. It's well worth replacing while you have it out.
So will the 4-speed lever fit onto a type9? Is the proper 4-speed lever straight or bent back?
