RWD, XE, MG Midget
Having spent so much time and money on my Mini project it is clear that it is going to cost at least 10 - 12k and with the best will in the world is going to be another 12 - 18 months unless I spend quite a bit more money on out sourcing work.
So in the interests of having something to drive relatively quickly I looked at buying something RWD which was either ready to go or didn't require too much work. And something else to work on when I am sick of looking at the Mini
My criteria:
RWD (Front engined)
Not a kit car / locost (Just preference)
£3000 total project cost
As fast as possible within the budget
Readily available (I don't want to spend my life looking for one)
Preferably old / 'classic'
Prefer fixed head not convertible
Which quickly results in:
MX5 - Most likely a 1.6 to be in budget, good handling but slow-ish
200SX - Pretty quick but most examples I looked at in budget were pretty tired, needing new suspension bushes / dampers / brakes and no shortage of blue smoke and the likelihood of some pretty scary rebuild costs any time soon.
So I ended up buying the slowest RWD car on the planet - 1275cc MG midget
I decided I couldn't buy what I wanted so I needed a front engined RWD base car which was as light and as cheap as possible.
MK1 / MK2 Escorts - out of my price range
Triumph GT6 - Heavy, rear suspension!, relatively rare
MG Midget - cheap, light, slow, lots around, cheap structural repair panels.
MGB - As per Midget just more expensive and heavier
TBH I probably should have just bought the MX5 as an instant RWD solution but hey...
The victim the day I bought it:
Sort of a cross between snot and diarrhoea as colours go, but that will change. Full MOT / Tax and I drove it home - slowly, very slowly. It wandered all over the place and felt like it was doing 6000 rpm at 70 mph in top, the steering wheel stayed where you left it, but the engine felt fine (as far as an engine with little power goes) and had good oil pressure.
It is absolutely tiny - which I really like, believe it or not the wheelbase is 4mm shorter than the Mini. It is far from being manly like a slammed / arched Tarmac spec MK2 Escort but I really like it and its simplicity, no I'm not gay or owt!
So the plan is 170 bhp / 750 kg = 225 bhp / metric tonne but hoping to come in less than 750 kg. Hardly ground breaking but more than enough to test my lack of driving talent.
Re: RWD, XE, MG Midget
sound great
Arch it ....
Throw away that softop and fabricate a unique roof
Good luck! This will be interesting.
this could be good keep us posted
I had one just like it nearly 30 years ago, put a ford crossflow in it , found the g/box tunnel quite small and not a lot of room to enlarge it, and i do quite fancy another.
Cheers guys, thanks for the comments.
Retro,
My plan is to keep it standard externally, except maybe for removing the bumpers (to save some weight).
I have seen very few arched Midgets that look any good but it may become necessary depending what I decide to do with the back axle as the std Midget one is going to expire pretty quickly. If I used a Ford live axle (English?) then arches would be required to avoid having to narrow the axle which would become too expensive.
PaulAlex,
Yes I know what you mean about a hardtop but again it would be too expensive within the project outline, I will have to buy a second hand standard 'works' hardtop as I have no plans to drive with the hood down.
Like this:
However if this were a "money no object" project then this would be the plan:
A Sebring Sprite rear end: These are £720 + vat (glass fibre) including screens
Another fastback hardtop:
But the plan is very definitely cheap and cheerful and use as many off the shelf parts as possible whilst keeping it cheap, so no bespoke fabricated parts etc..., the exterior will be 'ratty' as a respray will be too much
This was the 70 odd hp std A series engine
Tuning these engines is just no longer economic in my opinion, I did it 20 years ago, 1380cc, 45DCOE, LCB, Rimflo valves, belt drive, etc... £2000 for 110 fwbhp
e321,
Yes I am finding the same with the type 9 - it is very snug in the standard tunnel, which is going to require a bit of massaging to give some clearance, which is what I was doing today.
cracking wee cars their,great project
Sounds good project!
Looking forward to seeing this progress.
Cheers Turbo M, thanks for the positive comments,
Guys, just a quick question / request for info:
As part of this project I am looking into the pros and cons of changing the rear axle to an English axle
Firstly I would like to know the width (drum to drum) of the axle?
Was the 100E, 105E and the Escort MK1/2 the same rear axle, i.e. all English or were these different axles?
Any info gratefully appreciated
100e is different, anglia and escort is similiar but escort is wider, would think the anglia 105e would suit the best.
e321,
Cheers, having searched the archives I feel an Atlas will be a better bet but it's probably too expensive for this project anyway.
Either an English or an Atlas would need to be narrowed and I think that just is not possible to do economically?
I want to keep it a live axle as it will be just bolt on (In theory), IRS is too much work and after some weighing of components for the Mini project it has surprised me how heavy the MX5 based IRS will be. Live axle Mini!
Anyway, still working on the front end:
Shot blasted and painted some more bits, bumper mounts, ARB bits etc...
FARB, number plate holder:
Expansion tank:
Rebuilt the steering rack: New track rods, gaiters, reshimmed.
The rack was very stiff so I needed to polish the rack bar which has helped a lot.
Reconditioning the bumper mounts was a waste of time as I have decided to remove them as part of a weight saving exercise which with other changes saves about 25 kg without spending too much.
Also I have saved about 6kg from the base engine for both projects, the ITB's, Inlet manifold, fuel rail, injectors and linkages all weigh less the 3.5 kg total.
This is getting close to meaning the overall weight will be similar to the std car, but still a bit to go yet.
I have modified both the clutch and brake pedals so that I can move the pedal box another 10 mm away from as the leg room is a little tight. (Before = top, Bottom = after)
Basically I have removed material from the back of the pedal and added it to the 'front' and moved the pad a little further away.
Not a lot of progress but I finally purchased an ECU for this and my Mini project and will finish the loom design in the next week or so.
I know many will think it is overkill for this car and my other project but when you count the cost of all the additional units I will need and the requirement for a chassis data logger then it absolutely costs no more than the other options I researched.
My main driving force is the need for a chassis data logger.
When I purchased my Pectel T6 I did so due to a friend being a professional Pectel mapper on many high level Motorsport projects, when I started to look for this new ECU I had ruled Pectel out on the grounds of cost / necessity.
I wanted the following:
Traction Control - Slip based strategy (not RPM ROA)
Launch Control
WB lambda input
EGT (x2) K type
Knock control
ALS Control
WG control
Built in memory for data logging (Not PC logging)
8 - 9 Analogue channels for engine related monitoring / control
4 - 6 Analogue channels for chassis monitoring
4 Wheelspeed inputs
PWM for N2O control
PWM for Fuel control (N2O use)
PWM for fan control
4 cyl sequential injection
4 cyl individual ign coils
So to cut a long story short heres what I went and collected today from Cambridge:
WB Lambda input
Traction Control (Upgrade)
Launch Control
Knock control / input
3 MB data logging memory (upgrade from std 1MB)
Using the facility which allows me to use many unused channels as analogue channels I have no less than 24 analogue channels
Pectel SQ6
I no longer have my T6 which helped my purchase of this unit and all in all it cost a similar amount to the Autronic SM4 (Which was my main considered alternative) plus all the other external units I would have needed to get this level of functionality, plus I intend to use it on any future projects.
whoooops wrong picture
Further progress on the ECU loom, I have tried it in the Midget to see how it fits, the hope is the same loom can be made for both the Mini and the Midget but these mock ups will decide:
The ECU will be below the drivers seat to keep the weight low down and make it easily accessible as I will remove it when the car is not in use or parked up.
This shows the various loom transitions going up into the bulkhead, I have put the loom back in to establish the lengths for these various legs such as comms interface, PJB interface, Engine data loom, Engine power loom and engine grounds.
You can see the two bulkhead connectors in place in the upper bulkhead.
This where the bulkhead connectors come into the engine bay:
Here you can see the connectors for the TPS, Fuel pressure and Fuel temp
And because I should be able to power it all up in the next week or so I have made a download / comms lead to connect to the ECU, primarily it uses Ethernet for comms but will also have RS232 and CAN.
In relation to the axle why not look at what a Mallock uses. I'm sure its a midget casing modified to run an english Ford diff with quaiffe halfshafts....maybe on of the racers on here could confirm
great stuff keep it up
nice work. that wiring loom looks really smart. coming along nicely
You deserve to be knighted for that loom! You dont do homers do you?
Thank you for kind coments,
I have to be completely honest and say that my original plans were to just substitute the Anlglia axle and be done with it, owing to recent posts I have had to consider that lowering the rear roll centre will be beneficial at the same time.
The body mounted Watts linkage that Gary (Retro) uses is of interest but I am also looking at a similar 'A' frame system which doesn't need the Watts linkage and saves weight but also gives the advantage of a lower rear roll centre.
I can't emphasize enough that lowering the rear roll centre of a live axle is a very useful and desirable!
The two aspects I need to further consider are:
Roll steer
Anti dive / squat behaviour
I plan to look at kinematic models and post them if they are of any interest, I confess to being a bit of a suspension geek so I apologize in advance, I know that a Watts linkage is close to a straight line behaviour but not quite, I just need to understand what effects it
wow!! you dont mess about do ya... i really like this project, and will be watchin with interest... keep up the amazing work...
As you say, its close to a straight line.. and it is, along most of the travel, its only at the extremes of movement that your get the slight curve of the end plots. And its effects are minimal..
Re the squat, as long as the forward links can point at the C of G you can have full anti-squat, but, you'll also want to take that out, dropping the lower link down to neutral otherwise you'll never turn the car in.
An option.. screw adjustable front lover links either side of the prop.. pull up at the lights, wind the links up, and launch ... leaving the other car scrabbling for grip, just make sure you wind them down before powering out of a corner
The roll steer, both upper and lower links pointing down at teh front, will give you some usefull toe in roll, level links zero steer. upwards facing.. oversteer
Cheers Gary,
Yes as far as roll steer goes I definitely want to be able to adjust so that I can get Toe-in in roll, getting away from the toe-out in roll that a standard leaf spring with the shackle placed at the rear gives.
Looking at the photos of your LRC Watts link do you use a poly bush for the pivot? It looks that way on Montys car? If it is any reason why compared to a bearing?
What length have you used for the Watts inner pivot rod end to rod end centres, I have started to look at lengths between 70 and 110mm to see what effect this has on the straight line behavior, either worse or better.
I prefer to use as little 'anti' geometry as possible as it can tend to feel unnatural and less progressive at the limit, so I will make the forward link pickup points with height adjustment to give some but not full anti squat / lift (i.e. pointing at the CofG.) And use as little as possible so the car doesn't move around too much.
The other challenge with this car is the longitudinal links are quite short, the lower link will be about 450mm and the upper will be shorter (400mm ish), I understand that the Works Escorts started with a short link setup but the longer link setup was better - which makes sense as the change of anti squat / lift with ride height is reduced with longer links making the behavior more consistent.
Cheers Gringo, just spending too much time at work at the moment, but not complaining as we all know how quickly that can change
Mine are 100mm on centers , and the bush is for road use, the old nail NVH
I fitted a bush into a press and loaded it up with 1.5 ton, the movement was small enough that a dial gauge would be needed to take an acurate measurement... so i didnt bother.
Depending on how long your link bars are on the Watts, i think from memory these had more of an effect on the plot course than the pivot ..... but it was at the extremes of the travel.
You can get some extra length in your forward 4 links by placing then at the rear of the axle instead of center line ... that said the biggest problem i've plotted with short links is the fore and aft movement of the axle , the squat can still be adjusted with very short links .. of course in an ideal world we would have the links mounted in line with the C of G , shame theres a drivers spine in the way, allthough i've seen some 3 links that the center top link meets the chassis at the C of G vertical line. These running down the trans tunnels and being two bars mounted solidily to the top and bottom of the diff casing and meeting at a rod end, with triangular bracing all along its length, effectivly making a very long torque arm. I've never looked at these in roll, or RC height as i draw everthing long hand on paper.. then start plotting,
But that said theres some very effective american drag cars using short links and managing to lift both ends of the car on launch, allthough they have a wider spacing between top and bottom arms ... again, something which i havnt drawn out as i can get enough A/S with my current set up, the top of my body brackets are a bit higher than a standard Gp4 Escorts though
With regard to how much A/S you dial in, i would aim for full , but allow for zero, that way you have the best of all worlds.. Allthough its excellent for drag racing its also handy for moving the chassis from oversteer to understeer.
If you have a driver thats a point and squirt driver, on a short twisty course, give it loads of A/S .. let him charge up to a corner, lift the axle of the ground with braking, turn slow and then launch down the next piece .. if you cant change the driver, change the chassis
Long circuit, smooth flowing driver... lower the ammount of A/S to give him a car thats neutral to a tadge understeery... and allow him to feed the car from turn to turn.
If you tight for space at the front, make the axle brackets adjustable too. if you have room there, 3 holes above, 4/5/6 below could be possible? and will allow quite a lot of angle adjustment.
Cheers Gary,
Started to put together the kinematic model that I will use to look at the 4 / 5 link arrangement with Low RC Watts link.
Not quite ready yet as I still have to create the rear coilovers and the Low RC Watts
Rear discs are being turned down to 225mm OD (from 240mm) which has saved 0.4kg per disc as well.
Finishing the PJB this weekend, will post some pictures when finally done
I'll still stick with my string computer ..
