Dta ecu
Do I need to use a air temp. sensor on my zetec with R6 TB's to make the ECU work (I'm trying to do as much wiring before buying the ECU!) and if so where do you suggest I fit it as I don't intend on making an air box. (I have made some 5-1/2" long trumpets though!!!)
Re: Dta ecu
Don't know whether you need one or not with the DTA but mounting it just in front of the intake of the TB's should be fine as it measures the temp of the air going in. If you have a air filter you could also mount it through the base plate etc
